The AE will try and reverse if it senses it is jammed, to try and clear it. Lots of times the gears go bad in the auger assy. kap
I've been fighting this same issue with my AE insert. I've cleaned auger and tube, replaced optical sensor, checked wiring etc. Still getting an auger jam error...auger is spinning fine. Aargh! Any other suggestions? Stove is 2007, never had any issues.The AE will try and reverse if it senses it is jammed, to try and clear it. Lots of times the gears go bad in the auger assy. kap
Got it. Thank you. And, yep, it's the most annoying thing about the MVAE.The clicking motor is standard operating procedure, much to most peoples annoyance(me included). The way these motors were built, leads to the noise on low settings, or until you reach ssmed. on higher settings. Wish there was a fix as it is sad with all the other advances they did to make this one of the quietest running stoves, that they didn't address this. kap
On MVAE, or another stove?Auger motor is weak possibly need new one.Did same to me.
<b>Preface:I don't recommend doing this unless you have a spare motor or just want to tinkerThe clicking motor is standard operating procedure, much to most peoples annoyance(me included). The way these motors were built, leads to the noise on low settings, or until you reach ssmed. on higher settings. Wish there was a fix as it is sad with all the other advances they did to make this one of the quietest running stoves, that they didn't address this. kap
No problem RichardWell, I'll try a lot of things, but that may be beyond what I want to do until at least the end of the season (especially with a 1:3 success rate by a pro). I find that if I just run the stove on Manual Medium it goes away. It's when we run in auto and it runs at speeds below Medium (which auto tends to do, especially in warmer weather) that we hear the clicking. We would prefer to run it on auto, but the clicking is incredibly annoying, so manual it is. Eats through more pellets when temps are over 35 or so, but at least I'm not ready to smack the stove all the time.
This is a manufacturing / design defect, but one that tends to show up after year 1. Buyers of MVAEs out of warranty should be aware of this. Heck, I guess buyers of ANY of these over-complicated stoves should be aware of it. Live and learn... Great stove, but with some definite flaws. This is another of them.
Thanks for the info, Steve. Greatly appreciated.
