Oldman47
On my well peroxide was not an option. Local codes require the chlorine. I would be equally happy to use the H2O2 if it was accepted by my local health department.
The required water test pretty much tells them what I have done to the well.
Usually, they look for fecal coliforms which is an indicator of surface or subsurface water contamination of well water. Surface sources usually include animal waste. Subsurface can come from nearby septic fields.That required test is probably for bugs. Bacteria..
When my dog was a pup he got Giardia (beaver fever). After witnessing the affects of that, I flush and treat my questionable well after the spring thaw (high water in nearby swamp) every year, if not more often.
It was not a pretty sight or fun to clean up. It's been 6 years and he's still terrified of his own bowel movements.
I have many farms i do business with. I'm not sure but the levels of allowable bacteria(fecal matter,leaves,friggin' about any contamination) the state of feds have lowered to a point it's getting crazy. Almost impossible to pass on a good day. You take a half assed inspector that will take water samples after a spring washout? I've seen an inspector that took 14 water samples(different sites) taken after a big spring rain.........12 failed. Came back 6 weeks later, 10 of the 12 passed.
Just my 2 cents worth.
Yes, some folks confuse the word "chemical" with the much smaller category of "chemicals that I don't like since I have no idea what I'm talking about"
Hydrogen peroxide is a nasty chemical that can burn and kill a person that contacts it. It is hardly as safe as pure water with little bubbles of oxygen which is what the propaganda from some companies would like you to believe. H202 is a much stronger oxidizer than chlorine. It's a rocket fuel, a poison, etc. Like most chemicals, it is all about the concentration.
