goosegunner said:
				Der Fiur Meister said:
				goosegunner said:
			What the heck you have a Garn and a woodgun, what are they used for?
gg
The Garn heats the shop and the Wood Gun heats our house and DHW.
How would you compare them, either one stand above the other for efficiency or ease of use?
Do you have storage with the woodgun?
gg
Both are very good.  They operate differently, and have their own benefits.  The Garn really needs it's own outdoor housing.  We used a 20' long ISO shipping container.  The Wood Gun is installed in the lower level of my home.  Both have a vacuum induction fan vs. a fan that pressurizes the fire box.  If either unit leaks they simply suck in air.  I chose the Wood Gun for my home because I like the idea of making a fire in the morning without having to walk out in the snow and 4* temps (like it was here this am).  I've watched my neighbor filling up his outdoor "smoking hut" in the cold wind.  Doesn't look like fun.  His is a non-gasification type and he burns almost twice the wood I do with a smaller home.
Efficiency is about the same.  There were variables in the tests, but I've read independent lab reports showing the Garn in the low to mid 90% range primarily depending on the water temperature in the tank.  The Garn flue temps range from 300* to 350* at the stack (up to 400* inside at the gauge).  The WG is almost too efficient.  I'm careful to keep the flue temps above 230* minimum with normal temps running in the 270* range.  I've never seen it go above 305*
We use the Garn to burn scrap wood from shipping crates etc.  The Garn handles nails with no problem.  The WG does not handle nails.  Cleaning the ash from the Garn is easier, just using a square shovel.  The WG is a bit more tedious.  I use a wood ash vacuum cleaner which helps.  Being an open tank type testing the Garn is more critical.  Both light very easily and in a similar fashion.  Turn on the fan put the newspaper on top of the dry wood or kindling and light.  I can run them both with the door open.  I liked the manual timer Garn has on their controls so much that I installed one on the WG.  That way it doesn't keep running when the fire goes out (and suck the heat up the flue).  Burning the WG into storage greatly reduced the amount of creosote in the flue compared to the first year when it cycled on and off.
The WG really should have a seamless SS pipe or pipe with the joints sealed with high temp tape etc.  I have sectional black pipe now, but fabricated a flue pipe from Sch. 10 SS pipe.  It will be installed during the next warm spell.  The new flue pipe has flanged / gasketed doors on it at the bends to make inspection / cleaning a 10 minute job.  No more worries about leaking pipes.  We vent our Garn upwards (vs. down into a barrel as Garn recommends) with 15' of pipe just to reduce the smoke during lighting.  After the first 5 min. it's just steam for the most part, but with the unit only 10' from the shop I'd rather not have any smoke at all.  The shop roof and walls are steel so I'm not worried about sparks.  I intend to make a spark arrestor / heat recovery barrel that will sit under the exhaust elbow and then vent upwards.  The barrel will have an outer jacket for the intake air to run through and be preheated before entering the Garn.  Next year's project....
The Garn can be over fired, the WG just shuts down, but I try not to run the WG that hot.  Right now I have 100 gals. of temporary storage on the WG plus a 215 gal DHW preheat tank, but I'm in the process of welding up a 750 gal. tank from 12 gauge 201SS sheet and 304SS angle.  201SS sheet is much cheaper than 304.  I have a similar 215 gal. SS storage tank that I made for the DHW preheat tank.  A pex HX is used to transfer heat to the DHW preheat tank.  300' of 1" pex runs through it from my well before going into my LP hot water heater.  The preheat works so well that we no longer use LP.
The Garn needs to have fire brick replaced every other year....cheap brick - $12, easy 10 min. job.  The WG needs to have the center brick replaced every 7-8 cord, for me roughly every other year.  Haven't done that yet, but it's due.  The brick run $140 from AHS plus freight which was estimated at $50.  So I decided to buy 50 lb of refractory cement and make my own.  I suspect replacing those will take a few hours.
The Wood Gun has had wear on the door gaskets.  I'll be replacing those in a few weeks.  I added an "L" shaped piece of sheet metal to the rear door where the hot gases and ash sand blast the door gasket.  This seems to be working well.  When I replace the gaskets I intend to add the sheet in the high wear areas.  Hopefully this will extend the gasket life to 3-4 years.
It was difficult getting information directly from Garn, but the rep I bought from in MN was very helpful.  Wood Gun from AHS doesn't have reps in WI and information from them has been variable with the change of personnel they've had.
Both are excellent units.  Both made in the USA and I'd recommend either one, depending on your circumstances.....or if you're like me, both.
