Caveat, first post here, but thought I might have something of value to add.
I just recently installed an NC-30 in my approx. 1500 S.F home. I too was worried that it might be too much stove. However, after having used it for a few months, I have been very pleased with it. Here's why.
In my case, I equate the NC-30 to a car with a 500 hp V-8 only having to go 55 mph in the slow lane. It has plenty of horsepower when needed but with the winters here in TN, I don't need to rev the engine too often. I have yet to fill the firebox to its absolute capacity.
With outside temps in the 20's-30's, at 0600 I can load the stove about halfway, get the stove top temps up to around 600+, shut the air intake back and within an hour my house is around mid to high 70's. It will stay that way almost all day. Wood heat is unique in that it seems to heat everything in the house. Once my home gets to mid 70's, it will stay that way for a long time and is very reluctant to cool back down. Depending on outside conditions, I usually reload a half load again around 1700. I may add another log or two at bedtime at 2200. I will wake up at 0600 the next morning and my home is still at around 70 degrees.
For me at least, this stove is very efficient. I normally don't need all the power it has to give but if the temps drop into the teens or single digits, I know I've got extra horsepower when needed. The only drawback is you may have to deal with inside temps in the high 70's for a few hours immediately after a reload. If it gets uncomfortably warm, I'll crack a window. Having a house too warm in the winter is what I consider an executive problem. I will add that my ceilings are around 8' and my home is pretty tight.
I would have a hard time not recommending this stove to someone. Once you learn it's capabilities and burning properties, you can adjust the amount of heat to suit your needs. I'd rather have too much power than too little.
One more thing, to echo what has been said here numerous times, good wood is a must. I am burning hardwood that has been split, stacked and covered for over three years. With poor wood, performance is greatly diminished.
Good luck in your quest. I think the NC-30 is a great stove.
Jeff
Jeff
