chit! Hmmmm..Didn't know that!That's a lot more single wall than most stove makers recommend. Many say switch over to double wall if the connector is longer than 8 ft.
That really just means that it needs to be run hot and cleaned yearly, right?
How many feet of single wall will you have, if only a few feet over the 8 I dont think you will have a problem.
It'll be close to 12 feet with an offset with a couple of 45's. Haven't decided where the 45's are going....
What stove is this? Looks like an old Drolet, but I don't recognize it. The double-wall pipe for longer connectors is a recommendation, not a a requirement. It does make a difference on some draft sensitive installations and does keep the flue gases hotter. If you don't have excessive creosote build up due to pipe cool down I wouldn't worry too much about it.
It's going to take 10' of double wall to meet code.
The transition piece from single wall to double wall.
and a final shot of the overall project. Pay no attention to the mess........
What am I missing, here? Draft is a product of the temperature difference between indoors and outdoors . As that difference approaches zero, draft stops. In cases where it's cooler indoors than outside (your barn on a warm spring day ), draft reverses.SInce the temperature in the barn will likely be quite cold, close to outdoor temps, I can't imagine draft being a problem.
Another thing about pole barn stoves is they aren't likely to be simmered low all day. I expect that it will see full throttle quite often.
New stove, huh? Nice! My trusses are at 10' The pole barn is 36X40 so they just quartered the 40'.I'm right behind you mike. Stove pipe in the barn in boxes, stove to be delivered on Monday. I won't build the hearth pad until the chimney is installed since I want to be able to get the ladder under it. Our barns look to be similar in construction methods with large truss spacing, mine is 12 feet.
Yeah, it's been getting chilly over here...Seems like we went from it being too hot to get on that medal roof.... to frost in the mornings...
Wow, big temp difference from here. We had a low of 46F.
That's correct, the pipe goes in last. The normal way is to install the cathedral support box first, then install the flashing, then insert the pipe, lock in place, then anchor the flashing and install the storm collar. Seal with silicone.
