sloeffle
Thanks for the info @begreen. Next time I go in, I'll have to ask my doctor about this. I usually drink drip coffee, so I don't think it should affect my results too much from what I read in the article you linked. Unfortunately I inherited the gene from my dad.Coffee contains terpines. A couple of these oils are directly related to body cholesterol levels in some people. I have high-cholesterol from both parents and am on statins. Over the years I have been tested extensively to see if there was a way I could drop LDL levels. I'm already on a lean diet, but getting poly-unsaturated fats helped a little. I tried a lot of other different things (fasting, no eggs, no meat, niacin, etc.) and nothing made a big difference. Cholesterol testing should be done before eating but I was allowed coffee before the tests. Then about 7 years ago I just happened to be coming off of a fast and hadn't had coffee in a week. My levels were so low that the doc thought the lab made an error, but they didn't. Some research showed it was the unfiltered french-press coffee causing higher levels of serum cholesterol. I switched to tea in the mornings. Since then my levels have stayed down and my statin dosage dropped in half. My cholesterol hasn't gone up since this change. It's a bit of a bummer because I like coffee so I compromise and have filtered (Melita style) coffee occasionally.
This is not the case for everyone, but if you are genetically disposed to high cholesterol it's worth a try to see if eliminating coffee helps drop levels.
https://www.healthline.com/health/high-cholesterol/coffee-link
