Grizzerbear
Task once the first load has burned down to coals open the primary all the way to reload more wood. You then will have to go through blacktails steps again more or less. This really depends on the mc of your wood,draft, stove temp as to how soon a reload can be closed back down to cruise setting. If your wood moisture is high its difficult.Remember that your putting fresh wood in so it needs air to ignite. If you put wood in and leave the air set at low you are smouldering it and never giving it adequate air to ignite.Just try to burn previous load down to coals before you reload or you will inherently be babysitting it more adding a piece ever so often. I agree as well load that baby up and see what it can do.
