My wood is in the same range as your wood.Ok pulled one off the stack outside.....split it def more moister but still in the appropriate range....and View attachment 152920 dropped a piece on my toe!
What was your burn time before reduction plate?Had my plate put in today so I'm sure it will make a difference. My dealer was telling me that the new ones are coming with them already installed.
The I2600 is 2.6 and the PE Summit is 3.0 cu ft. The size of the firebox is square so the logs fit in so much better both north south or east west with no problems either way. I can fit in 12 logs. Overall it is a better insert.What's the size difference of the two fire boxes?
Brian I know you looked at the bypass and it closes but there has been people that went to check and found that the fork attached to the bypass was on wrong it should that it closed but for some reason heat was still going out. They changed the fork something about the arrow pointing in the right direction and they had good burn times. That big chunk of black wood in the stove showed a problem for sure.
Did you try the dollar bill test on the bottom of door?Yes
Yes.....I read that in this thread a while back and checked it, I think it was this thread....I know the wood I was using was an experiment to make sure my wood was not to dry,which is what I was using beforeCraziness is my only resort....my dealer and regency said they would come out to my house but I'm still waiting to hear from both of them.....I have bent over backwards as you can tell from this thread and have been more than patient in doing my part.....the main reason I went with regency was for there reputation, but they are proving to be misleading with their marketing and just a down right unethical company!!
When the stove is at the end of a burn you don't want the dollar to go on fireI've heard of it on here....haven't tried it....what do I need to do?
Another new guy with a CI2600. I'm not quite as unhappy with it as some. I didn't really expect to heat my house with it. We enjoy a wood fire and wanted to have it contribute some warmth instead of sucking heat up the chimney. It does that really well. Unfortunately it also incinerates wood at a rapid pace in the process.
It seems like the dollar bill comes out easily enough that I could stand to remove a washer or two. Unfortunately none of my sockets will fit on the bolt with the flange for the door strike on each side. What are you guys using to loosen those bolts?
I guess I'll need to contact my dealer and see if he knows anything about the plate for the air intake. Right now I get 4-6 hours of heat from a load. I would like to just get 8 hours consistently so that I can still have heat and refire quickly in the morning.
How have your burn times been and heat output?To remove washers from behind strike plate -- only my thin wall 7/16" socket would fit within the strike plate (space is 0.647" wide where bolts are). Standard 6-point Craftsman sockets wouldn't work (maybe a 12-point would squeeze in there).
