Wow, they actually put that in the manual, Regency just dropped a notch in my book.
You never EVER let it burn wide open for that long, cat stoves are simple, get to operating temperature and turn it down so it will burn slow and low and the cat will clean up the smoke.
Also they should have installed a catalytic probe so you can monitor the cats temperature, that is what I use to run mine,I use exhaust temp is just so I can see from across the room on my digital display that I need to close the damper on mine at around 400 with a max of 550 the alarm goes off.
This whole install and training they did on this stove is piss poor, the demise of this insert could have been prevented with good training.
) almost out of the heating season so there's no reason to rush the fix/re-install at this point. You have an exterior chimney and stand to gain the most from the upgrades your considering. Take some time to read the block-off plate instructions here and Mellow had one of the better threads on insulating the fire-box. Naturally you can't do anything expressly forbidden by the manufacturer and getting their blessing is a good idea but IMO as long as the insert has some room to breath it's a non-issue in my mind.
