Advice needed, ZC fireplace to Woodstove
Highridge
7
SE Massachusetts
Hello, looking for advice on my plans to replace my ZC fireplace with a freestanding Woodstove. The issue i have is having a non masonry chase. The way I see it I have two options, remove the ZC and stonework and make an alcove from floor to ceiling, or, what I’m learning towards, is removing the ZC, frame the opening with metal studs and durockand fill with more stonework and wall thimble. Both option will require a new class A chimney down the chase, but option two will allow a clean out tee that can be accessed from the basement. Hearth will be lowered to floor height and extended to meet stove requirements. Any thoughts?
[Hearth.com] Advice needed, ZC fireplace to Woodstove
How important is floor space? Are you choosing a highly radiant stove? Alcoves get tricky because you have to build to your specs that your stove choice dictates. Different stoves have did specs.
I vote class A inside a chase. Thimble at say 6’ off floor? Only reason would be maximum flexibility for stove choice.
Reactions: stoveliker
Stove will be either a Jotul Oslo or Firelight if I can find a decent used one. I know it’s preferable to go top exit but I’m thinking rear exit right into the thimble. It’s a decent sized room so having the stove stick out isn’t really a deal breaker.
Straight up is preferred but both plans can work as long as all clearance requirements are honored. Here is a ZC chase turned into an alcove.
Skip the Firelight F12, and consider a less radiant Jotul like the F45.
Reactions: Alabama_74
Both the F500 and the F600 are radiant stoves that would be best as a freestander and not in an alcove. They need at least 16" clear with a hearth extension for the side-door loading. This fits with the second option. How tall is the current flue on the ZC?
Reactions: Highridge and EbS-P
The flue is around 28 feet. Haven’t opened up the chase yet to confirm if it’s insulated but if not I will add some to help keep the flue temps up.
That’s tall may need a damper even with two 90s
That's more than sufficient with the two 90º turns in the second option.
Revisiting this, I have removed the ZC fireplace and now have an opening to the chase behind. I have decided to go with the Jotul F55 carrabasett (haven’t purchased yet) and turn this into an alcove all the way to the ceiling. Alcove size will be 60” wide to the studs and 24” deep. Based on the clearances I should have no issues with the width. My question is would Durock with a 1” air gap on the rear wall be considered a protected alcove or will I still need the 19” of rear clearance ?
As long as the cement board has a bottom gap of an inch or two off the floor and at least a 1" gap at the top, it will qualify. Air needs to be able to freely convect without obstruction behind it.
Hello everyone, I hope all is having a good day. I am very new to wood stoves as they are not to big in my area, northeast, Alabama, that I know of. Anyway I just built a house recently and the contractor installed a Heatilator E36 ZC fire place. We are happy with it for what it is, but during the past couple cold snaps lo and behold our heat has not been the greatest. This brought me to looking for a supplemental, secondary heat source. The wife and I both like the wood stove not only for looks but the efficiency we are reading they have.
We also really like the alcove look. This thread caught my attention and I wanted to ask a few questions if I may. Please let me know if I should start a new thread .
Attached photo is current set up, my idea is total the zc fire place out and frame the alcove to meet specs for the stove ,Jotul F55 and keeping the mantel and TV where it is pretty much. I have the room to move the mantel up to meet specs. I plan to brick the inside of the chase and the floor which protrudes in the garage. but the confusion is how high do I need to make the top ? What do I need to install for the top ? The house is on a slab . Is this idea even possible (web picture )? I apologize in advance but I am very new to this.
  • [Hearth.com] Advice needed, ZC fireplace to Woodstove
Start with the stove manual. Alcove requirement for stoves are more restrictive than for a stove out in the open. There are extra details to make it safe and legal, plan carefully. Consider getting a non-combustible mantel. There are some good looking options available that will eliminate this as a clearance issue.
Start with the stove manual. Alcove requirement for stoves are more restrictive than for a stove out in the open. There are extra details to make it safe and legal.
Thank you for the quick reply, looking at the above specs for the Jotul F55. Looks like I can meet all the specs, trying to find something to protect the ceiling for minimum clearance might tough, any suggestions ? Specs attached I appreciate it, I know I got a lot more research to do, wish I would found this place before I got the house built.
If this is being built from scratch, then using metal studs and cement board will make it non-combustible. Search on Alcove in titles only in this forum to see some examples. Here is one to get you started.
Thank you
