Does anybody know if there is a list of high efficiency water heating appliances that are sold in US?
Product Finder — ENERGY STAR Certified Heat Pump Water Heaters
Compare ENERGY STAR Certified Heat Pump Water Heaters, find rebates, and learn more.www.energystar.gov
I agree. Almost all the air to water heat pumps are self contained outdoor units that require just running the water lines to the outdoor units. No refrigerant lines, vacuum or pressure testing is required. It seems like they would be easy to install since the refrigerant system is factory sealed.I think he means space heating, not domestic water heaters.
I wish the market would catch up on space heating heat pump water heaters. We know the tech is there but just not readily available in North America.
Ahhhhh yeah, you are right based off of the list he had.I think he means space heating, not domestic water heaters.
COP of 2 at -5F…. Impressive but not a large increase. So you figure your ideal load and order a 1/2 ton larger and I thing these would work many many people. I want to see output at -30 if I lived where it got really cold. I don’t care about the COP at that temp.Looks like Mitsubishi upgraded their hyper heat models with a new deluxe model called H2i Plus. It has a significant jump in cold weather cop's and capacity. They are now rated to 100% heating capacity at -5.
I believe the prior version had 100 capacity to 5 degrees with a cop of less than 2 so quite an improvement.
View attachment 283005 View attachment 283006
500-1000 sq ft per ton….. no they are not for big spaces. But a single mini splits is not really not for whole house heat. And I don’t like the idea of heat pump as the only heat source. If a mini split could handle even 50-75% of the heating load that a great reduction in fossil fuel consumption.Though, 10-20000 BTU per HR may not cut it at -5 F...
Yessir. It is rather amazing how much of whatever other fuel you use, that a heat pump will reduce by using it just in shoulder seasons. My old wood oil boiler used a tank of oil and maybe 8 cords of wood a year. Switching to the gasifying boiler and storage got that down to maybe just 5 cords of wood with no oil. Added 2 heat pumps and I think I am down to 3 cords of wood. Plus now have really cheap a/c and dehumidifying.500-1000 sq ft per ton….. no they are not for big spaces. But a single mini splits is not really not for whole house heat. And I don’t like the idea of heat pump as the only heat source. If a mini split could handle even 50-75% of the heating load that a great reduction in fossil fuel consumption.
Try to get a southern HVAC tech to look into that when you argue that you want the system size for heating not cooling. I just told them the model numbers to quote.Their product line is a bit confusing for ducted systems pairing. It doesn't look like the H2i version is available in a 4 ton ducted version.
Did you add a second head to an existing outside unit or additional outside unit too? The local Daikin dealers are suggesting the multi-head units and the Fujitsu dealer is suggesting two separate units, one per floor, and are a higher price. The federal grant is nice too!We liked ours so much we got another one put in last weekend, at our cottage. Another Daikin. We're there right now for our first Thanksgiving weekend away from home. Rest of the family coming tomorrow. Still made a fire on in the stove when we got here, as much for ambiance as anything else but nice to have the cheap easy heat source. Especially getting up in the morning.
All individual separate units. Our Daikin guy highly recommended doing it that way. I couldn't understand exactly why at the time, but I think he was right.Did you add a second head to an existing outside unit or additional outside unit too? The local Daikin dealers are suggesting the multi-head units and the Fujitsu dealer is suggesting two separate units, one per floor, and are a higher price. The federal grant is nice too!
Sounds like your installer knew what he was doing. Single 1 to 1 splits have superior efficiencies and turn down ratios to multi splits with more than one head on the same condensers. The outdoor units on multi splits have really high minimum capacities and they are still pumping refrigerant through heads even if they aren't on. A single 1 to 1 12k unit can turn down to a few hundred btu/h while a large 24k btu multisplit can only turn down to often 6k or more btu/h. I read that Maine did a study and found most of them were installed incorrectly and way oversized and their efficiencies Their were terrible. The state heat pump incentive is now longer offering a good incentive for them and it only applies to single 1 to 1 splits.All individual separate units. Our Daikin guy highly recommended doing it that way. I couldn't understand exactly why at the time, but I think he was right.
It’s pretty standard practice for slab on grade construction. I agree if I I had a choice I would avoid it. And I would want to avoid condensation pumps. But sometimes it’s not possibleI dont think I would want any part of any heating system going through my attic.
