 So I think I'll have to defer to the professionals for the insulation job too.  And due to budgetary constraints, it'll probably have to wait until next year.  I just hate having to re-do things.  I'm all about doing it right the first time.  So this will probably bug me for a while.   :grrr:   I just wish I had known to ask up front.  Live and learn, I suppose.
   So I think I'll have to defer to the professionals for the insulation job too.  And due to budgetary constraints, it'll probably have to wait until next year.  I just hate having to re-do things.  I'm all about doing it right the first time.  So this will probably bug me for a while.   :grrr:   I just wish I had known to ask up front.  Live and learn, I suppose.bokehman said:I don't understand this too well. If the chimney is closed at the top why do you need a block off plate? If you install a block of plate and insulation you are wasting all the heat emitted by the SS liner. I can't see what energy you are saving around the insert because the cast iron box is inside a sheet metal shell that doesn't get hot once the fan cuts in. So, my question is, how does one "reclaim" the heat emitted by the liner?
I've got a vent further up the chimney chase that brings that hot air back into the living space.drdoct said:Hot air rises and so you are letting your hot air go up to the top of the chimney to be leached out by the bricks.
mellow said:That sounds like alot of blanket which = $$$$ depending on how tall your chimney is you might be better off using the vermiculite.
zhukpavlo said:I have an exterior chimney - not enough room to insulate - can I use this cerablanket on both sides of the 6" liner in the 7x12 flue (clay tile is 6.5 inches inside diameter - just stuff it in on both sides that are wider)?
burntime said:I insulated the liner and stuffed rockwool around the top 12 inchs before I capped it and have a rock wool layer over the block off plate. Anything will help. Now with the block off plate there is no insulation around the suround which is 1 more place heat comes out from.
tkuhe said:burntime said:I insulated the liner and stuffed rockwool around the top 12 inchs before I capped it and have a rock wool layer over the block off plate. Anything will help. Now with the block off plate there is no insulation around the suround which is 1 more place heat comes out from.
Do you think it would be worth stuffing rockwool or kaowool w/out insulation on the liner? I don't have room for insulation to wrap around the liner.
