Surprisingly, the settings of my dampers are the same as they were before. What I am finding is that the only difference is that it stays hotter, longer.
Here is my strategy.
My "max" heat setting for a high burn is when I set my drafts at 1 1/4 turn open each.
For a normal "I am home and it's chilly out" burn, I open the drafts 1 turn each. This usually results in about a 6 hour burn using hardwoods.
For overnight I close it no more than 3/4 of a turn open on each. This will let me go up to about 9 hours while leaving me ample coals to restart from using standard sized splits.
These obviously are dependent upon the force of my chimney draft, how tight my basement is, the type of wood I am burning, the size of my splits, etc, etc. Most anyone else in the universe's results will vary
It was extremely cold the other night (I wish I had borrowed my buddies infrared temp gun) and i wanted to get a maximum setting idea to give to the Mrs. (I have a thermometer on the slanted step between the lower and upper shelf's of the stove and another on the single wall stove pipe). The lady likes numbers to work with (and I am a bit of a geek as well).
I found that at 1 and 1/2 turns open on each draft I could reach about 650 degrees on the thermometer as measured right of center on this slanted step portion. (not the hottest part of the stove but is the most convenient location. I am going for consistency here, not a max stove-top temp) At this temp, I began to get a very dull "red glow" in an area about the size of 2 packs of cigarettes on the back of the stove. This could only be seen with all the lights turned off and eyes given a minute or two to adjust. When looking at the stove with nearly 30 years of burning on her, this is apparently the traditional hot spot as is evidenced by an ever so slight "bow" outward and a lighter color than the rest of the stove.
Also, with the thermometer here, I can reload perfectly every time when the temp gets down to about 175. At that temp, I have just enough coals to relight things without using kindling.
Nothing like being an analytical dweeb
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
I like measurements. Does that make me a bad person?
pen
