Stovecleaner
The easiest way to get the door off the sawdust box is to remove the chain & feed motor. The chain sprocket has a set screw. put the stove in test mode until the set screw is easy to get to. Once you loosen the screw, you can take the chain off. Then loosen the 4 5/16" screws off the feed motor. The motor comes off the bracket, & now the door is very easy to get off. When you put the chain back on, make sure you tighten the set screw on the FLAT part of the feed motor shaft.I am in the process of getting this stove cleaned up and ready to test fire this weekend and I have a question about removing the feeder door assembly. This is the older style chain drive and in trying quickly last night to remove the feeder door it seems there is a drive motor assembly very close to the door. Does anything else need to be removed to remove the door and clean out the feeder housing? I removed the wing nut but It did not seem like the feeder door wanted to come off easily past the motor assembly. I should also note that it looks like in the schematic that the wing nut is at the bottom of the door but it is actully in the center on my stove.
![[Hearth.com] Accentra 2 Age? [Hearth.com] Accentra 2 Age?](https://www.hearth.com/talk/data/attachments/183/183424-3464750a873704ea54a213845651be7e.jpg?hash=RdxVx5_6F-)
