MountainStoveGuy, I don't have an ash pan.
When scooping ashes, I try to always scoop them cold, and I always use a hepa vac and insert nozzle into the bucket (2 ft. tall).
I NEVER put nozzle past a couple inches down into my 2 ft. tall bucket, this ensures there is no chance of sucking up any coals at all (hot or cold), even thought I make double sure my coals are dead cold.
I clean my ashes out once a week, so they are pretty deep. My wife is the one who told me I needed to modify my ash cleaning technique, even though I thought I was doing perfect.
She showed me a film of ash on almost everything near my stove............ :cheese:
This is when I started using the hepa vac and nozzle trick. It looks like a mini tornado inside the bucket while I am dumping my ashes.
Even if I empty my shovel fast, there is absolutly no way the ash dust can make it out of the can as long as you keep the nozzle down in your can a few inches and just above your coals.
And if you are concerned about getting a hot coal in your bag, then remove the bag when your done and leave it outside somewhere. You will know in a couple minutes if you got a hot coal, so lay it on the gravels or somewhere safe, you'll find out that this is a waste of time as long as you only vacuum "ashes" inside the bucket and stay away from the coals.
On ash cleaning day, I simply get my vac and turn it on with nozzle stuck inside the bucket and start shoveling, I'm done in a few minutes and there is no dust unless I bump the shovel on the way into my bucket.
Note: they actually sell vacs that can be used with warm or slightly hot coals if you are concerned at all about the safety issues. If you are not 100% sure you can do this and NOT suck up hot coals, then obviously don't try it.
http://www.lovelessash.com/Ash Vac.htm
When I first started doing it and after completing the job, I left my whole vacuum out on my deck for a while just to be on the extra cautionary side.
Robbie
