I went to do some testing last night, and discovered this (that I would need 2 adapters). The double wall telescoping pipe does not connect to the adapter that connects the the Class A, it also doesn't connect to the stove. The adapter from Class A to stove pipe connects perfect to the stove, so I am hoping a single wall piece will work.
This project is way over budget. I am going to try the single wall connector listed above and just raise the heat shield on the back.
It looks like it will cost me over $100 to have a telescoping pipe in between stove and chimney. Is this worth it?
If I use the cathedral ceiling box, can I adjust it to right length and set the chimney pipe onto stove, then if I need to move stove pickup the chimney pipe? or do you screw it to the flashing?
