A Fresh Eko 40 with 500 gal Storage Install
Gasifer, One of the problems i have is in the living space there is 3/4 inch plywood under 3/4 inches of hardwood floor through the entire house. So i kind of have a cap on my warm cement. I bought a 2 way Air- and Slab thermostat but it would not work with my relay system for some reason. So i am hoping by controlling the slab temp tighter will help the warm temps. Cuz i know my slab cools off way before the air in the house does, causing it to work harder once a day rather then short cycles more often. And once the slab warms up it over shoots the set air temp.
Huffdog i am heating 3000 sq ft of slab on grade.
goosegunner said:
Franzen105 said:
So far very impressed with the Eko, Minus the Smoke!!!! The Empyre was great for not smoking. But i guess its better to have heat with smoke than having no heat.
is there a smoke hood build thread some where out there.
My econoburn seems to be the same way smoke wise. There is no way that I would want it in my house. I would look for a boiler with induced draft next time.
gg
Biomass has induced draft and still have smoke problems like the others if not done right.
gg
I have a biomass in the basement. For the first two weeks I thought I had made a mistake because of all the smoke. But now I have learned how to operate it pretty much smoke free. Definitely a steep learning curve with any of these boilers.
