Let me get this right. You going to reload in 8hrs?
That does it! I swear virtually all BK posts are related to the burn time which is soooo long, it needs to be expressed in scientific notation. Sometimes, I think I should purchase a BK just so I can make a post something like this...
"Hey guys, just bought a BK. Doesn't matter which model - they are all endorsed by the Council of Great Stoves. First burn - knew I had to have a smaller fire so that I can bake in the stove paint. Went into my kitchen and got 3 toothpicks (wood - no artificial colors/ingredients - couldn't test the moisture content as the probes were bigger than the toothpick, but felt dry). Took the wood load to the firebox and placed them on the surface. I was told in numerous forums, that a BK doesn't need a light, combustion just happens! Sure enough, as soon as I had closed the door to the BK and peered into the viewing window, and magically, the toothpicks started burning! Set the controls down for a low burn - just to get the stove up to temp. I watched the three toothpicks continue to burn like the proverbial burning bush in the Bible account - burning, but not consumed! Knowing that a BK is a 'set it and forget it', that's what I did. Checked in just before retiring for the night, and they were still burning! Pretty amazed - but went to bed. In the morning, the house was perfectly warm and no smell from the paint. Looked in the viewing window - and lo and behold - there were tiny beds of ash - just enough for me to toss in another toothpick to get it going again. A minute later - I put in 2 more toothpicks and I'm monitoring the burn right now. Amazing stove! Truly magical."
No mention of thermostat setting. Not a real BK post.
Nor mention of how the 8 hour reload will be on top of a lot of remaining fuel. Are you turning up the thermostat when you feel the room cool Bholler, or just stuffing in more fuel on top? A guy could manage the thermostat settings so that the room temp will rise a bit and fall a bit at the end so that you stay warm and can reload a nearly empty firebox.
Why should i have to go up to 5 cu ft along with a new 8" chimney when 2.8 worked fine?He needs a 5 cf stove, and he's running a 2.5. I'm not sure that the brand matters.
Not to much fuel left. And i thought bks were set it and forget itNor mention of how the 8 hour reload will be on top of a lot of remaining fuel. Are you turning up the thermostat when you feel the room cool Bholler, or just stuffing in more fuel on top? A guy could manage the thermostat settings so that the room temp will rise a bit and fall a bit at the end so that you stay warm and can reload a nearly empty firebox.
If it was me, it would be because I want to run my stove in its most efficient range of operation most of the time, and be able to have at least 14-16 hour burns in the coldest part of the year while I'm at work. (I can already do that with 2.5cf, but I think you need more BTUs than I do.)
Then i would only get 6 or 7 hoursYou need to set it properly though. Try turning it up higher if your house is cooling off before your fuel is mostly gone.
I think it isGood post.
Isn't the princess 2.8? Maybe the insert is a little smaller.
For you to burn a load of oak in 8 hrs and have the glass dirty like that is weird. Not my experience. Glass should be clean with a burn rate of an 8 hrs load. Just saying.
