- Aug 7, 2012
- 120
My wife threatened to light the Allagash NG stove in the living room when I came home for lunch today. We rarely use any form of heat for more than a couple days until November. There was no way I was going to start paying for gas heat this early in the year when we now have a wood stove. I knew my afternoon work schedule would allow me to be in and out, so I offered to light it up. The house is toasty warm but I have a few questions about my first somewhat prolonged burn.
I started off with some good and dry maple (Norway) and Tulip Tree. I filled the stove approximately 2/3 full after getting it hot with some kindling and small splits. It burned nicely, but quickly. Even with the air shut down, it was down to coals in an hour.
I then tried a load with just the maple. It again lasted just about an hour. I know the Buck 21 is a small stove but I expected burn times a little longer than this. I have somewhere around 26 feet of chimney. Is it possible I'm getting too much draft? Should I consider putting a damper in to lessen the draft and increase burn times?
My next question involves unseasoned wood, specifically red oak and hickory. The red oak was cut in July and split and stacked in August/Sept. The hickory was cut over a year ago and split and stacked in the same time period as the oak. The last time I took any moisture readings was a week or two ago and both read from the mid thirties to over 42 percent (which is the limit on my HF meter). I thought there was no way I could burn this wood this year, but thought I would try it out just to see what green wood looks like in my stove. The hickory really surprised me and burned really well. The oak is also burning well.
Here are some pics and a short video:
Pic of fire.
Certainly no black smoke coming out of the chimney.
Stack thermometer.
Video of the burn.
This is with one oak and two hickory splits placed on a bed of hot coals. The air was cut back after about five minutes. The pics and video are all from well after the air had been fully cut back.
I'm going to retest the moisture of the wood from the stacks when it is a little nicer out (ie. not 40's and raining) but does anyone have any idea what is going on here? From what I'm seeing, there is no evidence to suggest that burning this wood is creating creosote. Maybe I'm missing something here. I'd appreciate any input.
At this point, I'm thinking I'll have more wood than I thought to burn this winter. If I burn much of this stuff, I'll definitely make frequent trips up on the roof to check the chimney, but it seems to be usable, especially the hickory.
Pic of fire.
Stack thermometer.
Video of the burn.
