900 square foot hunting camp
mlasko
86
Western PA
Looking to replace a very inefficient older wood insert that eats the wood at our hunting camp. Realistically the camp gets used weekends and maybe 3 weeks straight in November for hunting season. Its hard to justify a brand new Jotul but I just can't seem to find the middle ground between a used stove or new one. I want something efficient that doesn't use a lot of wood but don't want to break the bank for limited use. My parents have an Jotul F3 that I'm in love with but can't seem to find a used one, yet. Are there excellent comparables. I found a VC Aspen but I'm not sold on the whole auto dampening deal. Any advice or recommendations would be appreciated.
The camp is an older brick building with a stone chimney with a clay flue. Its has a loft for sleeping but I just reinsulated the ceiling so I'd say the insulation situation is "adequate".
If new, the lowest cost would likely be a Drolet. (Used just depends on what is available to you between now and next October...)
@EbS-P has one.
First off are you looking for an insert to replace your insert or a stove?
If that brick isn’t covered, until it’s warm, it’s going to soak up heat and you’re going to use a lot of wood. Weekend use dictates a quick warmup which means a lot of heat… which means a lot of wood. You may not be saving a lot of wood with a new stove.
Things I would look at before putting a new stove in woul do be a blockoff plate in the chimney and looking to see if the current stove has a baffle.
Making sure your wood is dry will help also. Cooking off the water uses a lot of heat that can’t go into the room. New stoves like really dry wood.
I assumed freestanding because the OP mentioned Jotul. They don't have any inserts currently. If it needs to be an insert then then a decent used 1.5-2 cu ft insert from Century, Drolet, Regency, Quadrafire, PE, etc. would work.
Reactions: bholler
So yes, I’d like a freestanding stove not an insert. The brick is only on the outside of the building. There is also an lp furnace that I keep on 50 through the winter. The stove is simply for supplemental heat and enjoyment.
I just recently bought a drolet escape 1200 and love it, I'm heating a 12x16 shed insulated with 1.5inch styrafoam. It's the smallest stove in their small stove linup and it's way too powerful for my shed, even when the temps outside are -20 to -30. Runs perfect when shut all the way down and can run steady for about 3-4 hours. Not sure what it can do filled with only hardwood but I have a mix of wood that I don't even know what it is. I paid under $800 here in canada for judt the stove, found it on sale then found a company that price matches plus 10% off so I got it for a great deal. I know they usually run for like 1200 plus tax.
Ok but do you have a fireplace now?
Yup there’s a fireplace
Ok so you are also going to need a stainless liner run through that fireplace flue. And if you want the benefits of a freestanding stove it will need to sit infront of the fireplace not in it
I'm not sure this is possible for a drolet; the exhaust would.have to elbow immediately to a horizontal run to reach the flue - IF the fireplace is even tall enough for that.
I think an insert is the way to go
Post a picture of the fireplace and provide the measurements for it so that it's easier to make a good recommendation.
I think “fireplace” isn’t literal if I understand. I think we are just looking for a free standing stove that has a wall pass through into an exterior masonry chimney. There is an existing older wood stove to replace, not a fireplace since he said all the brick is on the outside.
@mlasko Please clarify if there is a hearth and an open fireplace, or a wall thimble. How high is the thimble?
So here is what I'm working with. I just took out a huge Brunco stove. I just didn't like it and I'm beginning to see why. There was not liner. The stove itself took up most of the fireplace opening. I do not want an insert. I much prefer to have a stove. I have been looking at the Vermont Castings Aspen, but I'm concerned about the auto dampening do hickey. My dimensions are to work with here are 26 inches high, I have more than 36 inches of depth, and 36 inches wide. The opening to the flue is 7 inches so I think I'm good there. But there will more than likely be a little elbow in there I'm guessing.
View attachment 327260View attachment 327261View attachment 327262
If going with a stoveyou want it infront of the fireplace not in it. If you want something in the fireplace get an insert
Reactions: EbS-P
And not a radiant stove. An insert is convective and can be put in without the front surround in some cases.
Reactions: bholler
Any recommendations? I guess I should entertain an insert...I really don't wanna go with a surround. Much prefer a stove but just not sure what to get.
Regardless of what you get, include an insulated block off plate, especially if the chimney is on an outside wall.
Reactions: EbS-P
An insert without the surround. Drolet is a good value.
A Drolet Escape 1800 or a TrueNorth TN20 insert will work.
