Englander Control Board is Going?
BillM2
86
Mid-Hudson Valley
My Englander 25-PDVC start-up is not working as it once did. It starts, then shuts down occasionally. I've cleaned the stove regularly -- after two bags and everything seems to be working fine. The auger is turning, the blower kicks in when it should, but then it goes into shut down mode. Has anyone had a similar situation?
Thanks!
My advice is to title your topic with Englander control board problems. You will get a little more help that way.
Just saying.
eric
Take a look at the vacuum hose that connects to the combustion blower. The end that attaches there can get hard and cracked from the heat. I've had that happen. I keep several feet of 1/4" fuel hose on hand. It fixed that problem for me a couple years ago
