I have a Summers Heat 55SHPAH. It has a manufacture date of August 2011 and was installed in the fall of that year. This is my fourth heating season with this stove and it has never functioned properly.
Over the past 3+ years I have made numerous calls to England Stove works to help diagnose the problem. That has proven pointless as they insist that I must be burning wet pellets (garage stored off the ground), have a dirty stove, etc. Basically just trying to pass the buck for the performance of their sub par product.
I have tried multiple brands of pellets, stove configurations,control board settings; basically to rule out any error on my part. Everything i have tried, has yet to yield productive results.
Themain issue I am having is the stove does not produce any usable amount of heat. From what i can determine (along with several ESW techs) everything is functioning as it should;augur works properly, oak installed, passed the dollar bill test, complete system reset, no air leaks, burn pot sits flush. I only have a 1200sq ft ranch house (well insulated) and this stove fails to keep my house at even 60 degrees on most winter nights (northern Pennsylvania) when ESW claims that this stove is good for nearly double that amount.
What little heat the stove does produce does not change regardless if the stove is running in level 1 or in level 9. Currently i am running a 1-4-1 as is specified by ESW.
I have run out of ideas for potential solutions. If i can't get this resolved, this stove will go straight to the landfill and i will have to buy a Harman.
If anyone has advice, please fire away.
