There is a bill in the Rhode Island house right now (H7064) (http://www.rilin.state.ri.us/BillText10/HouseText10/H7064.pdf) that would retroactively ban nearly every wood boiler in the state as of July 2010.
key points:
23-23.7-5. Manner of installation. -- (a) Effective July 1, 2010, no person shall install a
Phase II outdoor wood-fired hydronic heater unless it is installed at least one hundred feet (100')
from the nearest property line and has a permanent attached stack that is at least two feet (2')
higher than the peak of the roof of the building served by the outdoor wood-fired hydronic heater
and the peak of the roof of every other building within three hundred feet (300') of the outdoor
wood-fired hydronic heater.
23-23.7-3. Seasonal prohibition and nuisance conditions. -- (a) No person shall operate
an outdoor wood-fired hydronic heater between the first (1st) day of April and the fifteenth (15th)
day of October, both inclusive, in any year.
(b) Only persons registered with the contractors registration board and licensed to install
an outdoor wood-fired hydronic heater may install an outdoor wood-fired hydronic heater.
(c) No outdoor wood-fired hydronic heater may be used as a primary heat source for any
residence and/or commercial structure.
(d) All existing and installed outdoor wood-fired hydronic heaters that do not meet the
emission standards as set forth above and shall have a set back of five hundred feet (500') from
any property line along with a stack height of two feet (2') above the peak of the nearest
structure.
It is unreasonable to make this bill retroactive. Problem installations should be dealt with on case by case basis. There are plenty of people who spent a lot of money to make a legal, permitted, approved installation, and use wood as our primary heating source, offsetting oil dependence, reducing heating costs, and promoting a carbon neutral heat source in the process. To suddenly prohibit use of these existing legal installations is a bad precedent and certainly would create hardship for some, especially in these economic times.
If you are in RI, please call, email, etc your state rep to voice your concern with this proposed regulation.
Thanks!
key points:
structure.
Thanks!
((broken link removed to http://www.ricentral.com/content/view/174660/239/))
