I have a couple questions on laying out a "European Open" (EO) style system where the system is "pressurized" by the weight of a water colum in a high mounted open overflow tank, as opposed to being tightly sealed and pressurized by the air pressure in an expansion tank like we are used to with closed systems...
1. I have seen numerous references by people here, and in articles on hydronics elsewhere by folks like Siegenthaler about the point where the expansion tank is attached to the system being the "Point of No Pressure Change" and the importance of setting up circs to pump away from that point in order to work best... I understand the science behind this, but am not quite sure where the equivalent point would be in an EO system - would it be the point where the overflow tank line connected to the system?
2. Does it matter where in the system one attaches the line to the overflow tank? It seems like most of the diagrams I've seen show the line as a dedicated line connecting down near the boiler, and essentially not being part of the main heating loop flow... However as I understand the physics, as long as one doesn't cut off the flow path to it, there is no reason the tank couldn't just connect to a tee off whatever heating loop was handiest to the tank location... Is this to preserve that point of no pressure change?
Gooserider
Gooserider
