Lorde
I agree. I just thought the magnetic thermometers were not very accurate and I also can't get a very accurate reading on the griddle with the IR thermometer. The magnetic thermocouple worked out great just have to get off the couch to swap it with the cat probe on the AT100. Once I have some more experience I guess I will just monitor STT with the mag TC then once I engage the cat switch over to the cat TC until the next cold start.There are many here that can run the stove properly with out all of this.. you may be over complicating over thinking it.. most including myself are using a cat prob 1 magnetic on the griddle and 1 magnetic on the stove pipe..
When starting from a cold start looking at the magnetic on the ST and stove pipe getting up to temperature.. once you have established proper temp and coal bed close bypass and look at cat prob to ensure it lighs off.. if not repeat above
on a hot reload.. cats already running.. open bypass load wood and Immediately close bypass as nothing needs to be reestablish..
on a miled restart.. cat at about 600.. load wood reestablish some draft and closed bypass and cat should light off again..
Last night was fire #2, took a bit to establish a good coal bed and by the time I had one STT was cresting 600. Added three splits on the big side of medium, waited a few minutes for them to catch then closed bypass. Started to cut back air around 850 and fully closed by 1000. Cat peaked at 1040 which is about 400 lower than the peak of fire #1. Temp stabilized at 1000 for a few hours then dropped steadily as it burned down.
All seemed to work well. Not sure why fire #1 cat temp was so much higher can only assume differences in the wood split size/species/moisture.
I also have not checked visual smoke from the chimney yet, will start to take a look. Overall am I just checking to see that there is no more smoke once the cat lights off?
![[Hearth.com] 2022/23 VC Owner thread [Hearth.com] 2022/23 VC Owner thread](https://www.hearth.com/talk/data/attachments/308/308362-9af746e1d7294023c368feaa3bfd0399.jpg?hash=3uc5tOG-7O)
![[Hearth.com] 2022/23 VC Owner thread [Hearth.com] 2022/23 VC Owner thread](https://www.hearth.com/talk/data/attachments/308/308363-892c8924e6185bb9be56bf11714f0885.jpg?hash=MqMcKmSj1Z)
