@BKVP …… any info on this special coating for cats? Looking to buy a spare cat to have on hand. It would be awesome to extend the end of the active burn cycle. Thanks!I've been running a ceramic cat in one of my BK Ashford 30.1's, and the OEM steelcat in the other for at least 4 years. I'm more cautious with hot reloads and such on the ceramic one, since they're theoretically less able to handle thermal shock than steel, but overall I prefer the ceramic.
Do note that my ceramic cat has a special (then just in prototype phase) coating, which I think BK makes available publicly now, BKVP can give more details on that. I think this special coating may extend the tail end of the active burn a bit, and I can say for sure it has had a longer lifespan than I've seen reported by others here. I think I'm starting my 5th season on it, and probably close to 30 cords thru it, and it is still working and looking just fine. I won't pretend it hasn't lost any of its magic, but it's still doing well enough.
Some folks claim all ceramic cats hold active longer than steel, due to added mass. I really doubt this, there just isn't enough mass there to make a real-world difference, in the face of the amount of thermal energy you are pushing thru it. I think these differences are mostly imagined, likely the result of comparing a NEW ceramic cat to an OLD steelcat.
Just try to avoid too many hot reloads, and be sure to run the stove in bypass for a few minutes, before opening the door on a hot ceramic cat. I'm not sure how much the cat really cools in a few minutes on bypass, I honestly have my doubts, but that's the conventional wisdom repeated in stove manuals and everywhere else. Ceramic is better than steel in almost every way, excepting it's durability to thermal shock (cracking due to unequal temperature / thermal expansion).
Yeah that's a fine line to find. Currently in the low 30's at night and my evening reload time varies so it's hard to exactly estimate how much to load. Yesterday morning it was almost completely out and just going out of the active zone but this morning there was a 2" deep glowing coal bed and the cat was at the 3:00 position.Try loading less wood if the burn cycle is too long for this time of year.
Yes Crummy, you’ll be fine doing it as described..Is it ok to reload onto a coal bed when the cat is still very hot? I have read about not opening the door onto a hot cat as it will cause damage but if it's bypassed for a couple minutes before opening then is it ok? I am finding that I'm down to just coals in the morning but stove is still very hot. When it's time to leave it's time to leave so I can't sit around waiting for it to cool down.
I do it quite often and use stovelikers approach. It probably kills the cat quicker but it’s tough ( for me) trying to predict weather and how much to load. I can say that replacing the cat was super simple so I’m not going to change. I definitely recommend keeping an eye on the weather and that helps a little bit to avoid over heating the house but these stoves have a way of sucking an extraordinary amount of heat out of a small load sometimes especially a big chunkIs it ok to reload onto a coal bed when the cat is still very hot? I have read about not opening the door onto a hot cat as it will cause damage but if it's bypassed for a couple minutes before opening then is it ok? I am finding that I'm down to just coals in the morning but stove is still very hot. When it's time to leave it's time to leave so I can't sit around waiting for it to cool down.
34° this morning and up to 42° now. Been burning 24 hours a day for 17 days straight.50 this morning, 58º at noon. I turned on the heat pump. Neither I nor my tomatoes are ready for summer to end.
I like to visit AK, it's a beautiful state, but I could never live there.34° this morning and up to 42° now. Been burning 24 hours a day for 17 days straight.
I know. But the person was asking there so I posted that thread here so those willing to can go to that thread to give feedback. Just trying to be helpful.There are a lot of past threads and reviews on this stove. It's been out for a long time. That would be the best place to start.
It was 45.7 here in eatonville this am. Can’t burn till I get done drywalling and tiling the stove room so I’m stuck with the ductless heat pump. It’s supposed to be adequate and I’m super slow so I guess I’ll be finding out.50 this morning, 58º at noon. I turned on the heat pump. Neither I nor my tomatoes are ready for summer to end.
That is a spanking clean glass😜Here’s what it’s supposed to look like with bk gasket. It’s thick. This gasket is also a few years old with lots of use.
View attachment 299071 View attachment 299072
I clean it when I sweep in late spring and then all summer it stays pretty clean.That is a spanking clean glass😜
I'm a hard wood guy and 3:30 setting for me is a rippin fire, I normally set the t-stat before 3 or so and get small lazy candle like flames, using a combination of large splits in the center with smaller on the sides gets me long burns since the fire seems to burn from the center out ward like a V.Makes me think smaller is better for a fuller load and better drying
Yup. Been doing it for years. Get out of bed, move the lever from combustor engaged to combustor bypassed. Go pee. Let the cat out. Make coffee. Open the loading door, add fuel, close the loading door. Pour coffee. Check the stove, go take a shower.Is it ok to reload onto a coal bed when the cat is still very hot? I have read about not opening the door onto a hot cat as it will cause damage but if it's bypassed for a couple minutes before opening then is it ok? I am finding that I'm down to just coals in the morning but stove is still very hot. When it's time to leave it's time to leave so I can't sit around waiting for it to cool down.
The easiest and fullest would be on cube of wood cut to the exact dimensions of your door opening.Small splits makes the Tetris game easy
