This does not look like fun. Be careful out there.I’ve got to go cut a tree off a friends neighbor’s house. Yaaay! ( not) this is all I got to go by.
I believe they were just emissions recertifications that spawned a new model # (could be wrong). Although the newer ones have the ash lip under the door flipped up (the right way). Wish I could cut mine out and flip it around.Anyone know the differences of the princess pe1006/pej1006 vs the 30.2? I’m curious.
Thought the same thing. Probably would be breaking some law ha!I believe they were just emissions recertifications that spawned a new model # (could be wrong). Although the newer ones have the ash lip under the door flipped up (the right way). Wish I could cut mine out and flip it around.
Correction. The older princess pe1006 vs the princess 32.Are you asking the differences between the 30.2 and the princess? There are several differences besides aesthetics. The biggest one is the 6" deep belly on the princess.
I’d get the 32. Tested very very well for low emissions and high efficiency. Supposedly the same cat as always so cheap cats. The flue collar is taller which should help with the weld blob interference.Correction. The older princess pe1006 vs the princess 32.
Any idea what the operating differences are besides the flue collar?I’d get the 32. Tested very very well for low emissions and high efficiency. Supposedly the same cat as always so cheap cats. The flue collar is taller which should help with the weld blob interference.
Gotcha. I have a 1006 princess currently just inquiring about any major revisions or upgrades.I’d get the 32. Tested very very well for low emissions and high efficiency. Supposedly the same cat as always so cheap cats. The flue collar is taller which should help with the weld blob interference.
The base is not welded on like with my ultra. You can choose the base. The convection deck is now built in and standard. Taller collar, better emissions specs, properly upturned ash lip. That’s all I have been able to figure out so far.Any idea what the operating differences are besides the flue collar?
Only thing you could upgrade is the new style door latch if yours is like mine with the welded interior nut and round latch.Gotcha. I have a 1006 princess currently just inquiring about any major revisions or upgrades.
Yes, things will settle with time, just adjust your t-stat for your desired heat output and let the stove do the work, once the cat settles some you will find the needle hanging around 1 - 3 o'clock, on high char burns it will be around 4 o'clock.Ok thanks. This only the 3rd burn in this stove. I'm transitioning from an Eglander Madison. The Princess door glass is mostly black, even tho I'm burning above mid been on the Tstat. I'm assuming that is just the nature of the beast.
I'd advise no more than 2-3 logs per load. Depending upon log manufacturer, there can be 40k-60k Btu's in each log!
