![[Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK) [Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK)](https://www.hearth.com/talk/data/attachments/270/270157-59b295ef1dc3054253ff71b689d7baae.jpg?hash=ch9CHHztmx)
![[Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK) [Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK)](https://www.hearth.com/talk/data/attachments/270/270158-512e2db0cce3ed7ded181e70fffe67c3.jpg?hash=q9zT-jhET8)
So jealous! Makes me want to lay out my three press logs for a pity partyMid 20s tonight, still have snow on the ground, time to load her up. This is Doug fir with a couple of maple chunks too. There was one leftover chunk that I slid to the side. Stove is warm but not hot. I got all of it in except for one. Bottom up kindling fire to be started with the torch in an hour or so after it gets dark. View attachment 270130View attachment 270131
Really? I’ve been warned against itYou know, you can stuff way more than three in there. I think I was up to 7-8 niels at a time when I tried them out. Think of the firebox as a fuel tank. Fill her up and choose a burn rate.
I threw in a 25lbs of those press logs, T stat will keep you from over firing, once you get some fire on them and an active cat, turn the t stat down a little and let nature take its courseI think if they could make those press logs so a guy could stuff his stove with them and not worry about over firing from they’re initial extreme heat that lasts 1-2 hours, they wouldn’t be too bad.
By Niels, you mean northern Idaho energy logs? Just to be sure. I have those. Sorry for my ignorance. I’ve only burned with an old stove that never cared
you got it. That's for what it stands for.By Niels, you mean northern Idaho energy logs? Just to be sure. I have those. Sorry for my ignorance. I’ve only burned with an old stove that never cared
I will use the dial to find a setting that you feel it is giving you the heat you need. The cat prob is more useful to know when the cat is active/inactive.Now that we are getting into colder weather, I need to get more heat out of the King. How important is it to keep the needle in the white area at the top end of the combustion range? I keep trying to set it so it is very near the top end of the range but I overshoot quite often. The stove doesn't seem to be in any distress when I overshoot but I would appreciate hearing from more experienced burners about how high they run their Blaze Kings. Thanks in advance.
I do that regularly. Im trying to heat 4000+ sqft newer construction. I have to run my stove hotter than most on here. The stove doesn't seem to careIn theory, according to the manufacturer, if your installation is proper and your stove in good repair, then you can fully ignore the cat meter after it crosses the active line and your bypass is closed. If you need maximum heat then spin that thermostat all the way.
![[Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK) [Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK)](https://www.hearth.com/talk/data/attachments/270/270175-eed7ee4b367a57440e60325ef434e5d2.jpg?hash=4kUls5UEEo)
I hate you.
NEW BK KE40 BURNER
Hi folks, I am an old wood burner and Hearth reader, but I have recently purchased a new BK KE40 classic. The first thing I did was to read completely through this thread from page 1, and it really helped me get going. I do have one issue that I am working on and it has to do with getting enough heat.
I am in central Montana at 5,000 ft. elevation near the continental divide. I have a 3,700 sq. ft. log home on two levels. It has vaulted ceilings in some parts and a very large amount of glass. So I am asking a lot I know. The stove room is on the first floor, where we do not spend much time. I have two box fans directing heat up a large staircase to the upper living area.
Another problem is our wood. We really only have old standing dead beatle killed Ponderosa Pine here for firewood. It has been dead for a number of years and is quite light. Also, these splits are quite irregular, as P. Pine has a large amount of knots and limbs all up and down the trunk and they have to be split radially around them.
I used the stove that came with the house for the past 30 years, an old Earthlink model 101. It heated the house quite well, but it did smoke, and I went through a lot of wood, about 10 cords per yr. Last heating season I decided to make an upgrade and got a Lopi Liberty. This also heated the house well, but it had two disadvantages. One, it had such a small firebox that I could only put two big splits in, and two, I had to reload about ever hour to an hour and a half. For overnight burning, I had 3 alarm clocks to get me up three different times to reload. Well, one year of that was enough.
I really liked the deep firebox of the 40, and the fact that it could go much longer. I absolutely love this stove and the long heat, and what is even better, it is so even and controllable. However, my dealer warned me that total heat output of the BK would be less than the Lopi, and he was right. The stove makes a good amount of heat, but the problem is getting it out fast enough. The main problem is the wimpy fan. The Lopi fan was at least 2 times more powerful than the BK, and it could really pump out the heat. I have the fan on high all the time, and the thermostat on about three quarters. The thermometer is running right on the edge of the far right black label. It is giving me 8-9 hr. burn times overnight with heavier purchased Lodgepole pine, and about 6 hrs. with the P. Pine. That might not sound like much to you, but I am ecstatic with it.
The problem is that at colder temps, I can not get enough heat out of the stove to keep the whole house warm. What I have done is get a good desk fan and aim it directly at the center of the top of the stove where the catalyst is. This makes a good deal of difference. It makes the stove room really nice and hot, and allows for enough warm air to get blown upstairs to keep it decently warm.
We have not had really cold weather yet and I am concerned when we get down to zero and below that even this will not be enough. Any good suggestions to get more heat?
Maybe a little more info about your setup can also help. Maybe you are wasting heat up the chimney etc.NEW BK KE40 BURNER
The daughters teased me about the missing spots but I’m home tomorrow so wasn’t interested in splitting wood just to get a more complete fill.
That looks like some dense fuel too.
I was having same problem. I have a lot of sq ft to heat. I removed the top and fan kit. The fans use 65 to 70 watts for not great air flow. I bought this dc fan on Amazon that uses 23 watt only brings much airflow /heat from the stove.NEW BK KE40 BURNER
