Winter is coming.No kidding. This has got to be the warmest winter I can recall since I moved down here. We are saving a ton of wood, but OTOH I don't hear the fat lady singing yet..
In my house I start running the blower if it gets to around freezing or colder. Anything warmer and I find it's really not necessaryI think that the blower is out of the equation, the wife objects to the aesthetic aspect (or the lack thereof) of a power cable running from the stove across the hearth. She has a point there.
But we do have a ceiling fan less than 10 feet from the projected stove location, that may actually be enough.
He works at a stove shop as well, and can get you all kinds of great deals with his employee discount.What part of indiana you from?
I’ve got a full wood box and 1200lbs of coal in the basement just Incase it gets cold!He used to have "southern" in his location. I opined that it was a stretch.I live about ten miles from KY..that's southern.
I’m happy to get a deal when I can! I don’t mind having a few extra stoves sitting around either!He works at a stove shop as well, and can get you all kinds of great deals with his employee discount.![]()
There may be substantial variability in these fan sets, from one unit to another. I bought two pairs, for my two Ashfords, on the same date / same order. However when they arrived I found one could be run nearly silently... very, very low speed, and the other could not be burned down nearly as low. I was able to adjust the low setting so the fast one would match the slower one, but I'll warn you that I somehow managed to blow up one of the rheostats in the process, so be sure you use a plastic screwdriver on the trimmer if you do this.Hm, not sure about that.
That is crazy cold. We are in the same province and this morning it was 7*C or 45fGot to -39*C here last night. I had the fire turned down to my low setting so that it wouldn't go out overnight, and ran the fan on low. This worked to keep the house between 16-17*C with the furnace turning on about 10min/hr starting around 02:00. When i got up this morning, i reloaded the stove, and after prepping the load, set it at a med-high setting with the fans on a high setting. i was able to get the house up to 26*C in the stove room, and 19*C in the furthest corners of my house within half an hour. Check 2 for the fan. Neither of those things would have been feasible without the fan to move the air off the stove. And I do have a ceiling fan in the stove room, but it doesn't do what the stove fan does - not even close.
With that being said, i'm fairly confident that some of you fellas don't see -40*C...
ya, you're in ottawa, and i'm less than 100km from the ON/MB border. we definitely get different weather!That is crazy cold. We are in the same province and this morning it was 7*C or 45f
I 100% agree with you. Once you spend few days in -40 then the body gets used to it. The wind however not so much.that southern ontario winter damp i find to be more bone chilling than a nice dry -40 up here
Fans give you an optionWell, not really an Alcove, more like two built in cabinets on both sides about 60" apart. Those are about 2' deep until 3' high, and 1' deep until they top out at about 7' up. The ceiling is about 14' high.
Not sure anyone could get used to -40c. I think im gonna die when it gets -15f here and a high of -2f.Got to -39*C here last night. I had the fire turned down to my low setting so that it wouldn't go out overnight, and ran the fan on low. This worked to keep the house between 16-17*C with the furnace turning on about 10min/hr starting around 02:00. When i got up this morning, i reloaded the stove, and after prepping the load, set it at a med-high setting with the fans on a high setting. i was able to get the house up to 26*C in the stove room, and 19*C in the furthest corners of my house within half an hour. Check 2 for the fan. Neither of those things would have been feasible without the fan to move the air off the stove. And I do have a ceiling fan in the stove room, but it doesn't do what the stove fan does - not even close.
I imagine every setup works different, but at my MIL's, in a small stove room at one end of the house, with two doors, the ceiling fan disrupted the natural stratification of hot air to the ceiling, pushing that hot air downward and roasting the stove room.I do have a ceiling fan in the stove room, but it doesn't do what the stove fan does - not even close.
Supposed to be -11c here Monday night, apparently a low we haven't seen in 20 years!
We're seeing lots of new snow in the hills around us over 700 feet, but lots of rain locally.im just south of you but at 750’. Looking forward to the cold. Expecting teens Fahrenheit
checked mc on my Doug fir fuel today and it’s 13-14%. my cat has passed 12000 hours and is not doing the job on medium/low settings so this cold snap will allow me to run it hot enough that the primary combustion can shoulder the load.
will get a new cat on order this week.
![[Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/255/255145-4cf4cb640cf419dcb170108aae78a9ae.jpg?hash=3CFfxIUavp)
![[Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/255/255146-a6cda44723d6dcaf55594a1d0114c8d2.jpg?hash=DuIBDPPXEF)
![[Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/255/255147-c2a0e9b5161c07adc012dbb127fea7fe.jpg?hash=KmGrRWZ5XX)
![[Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/255/255148-2f808d3dfab7cab0eb64aaf8bb67f736.jpg?hash=f8E48NnczM)
![[Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/255/255149-38b7f0a1653d1b82dfa4dfff7ea3c20f.jpg?hash=UOxguOsoIy)
That was me...Somebody asked me what brand of tires I was burning so they could avoid them...![]()
