Indiana wood
Why do rounds last longer than splits? Do they put off more heat or just longer heat.
asking for a friend
asking for a friend
Less surface area..Why do rounds last longer than splits? Do they put off more heat or just longer heat.
asking for a friend
I thought that had the potential to shock and damage a ceramic cat.
The worst than can happen is a chimney fire from the creosote. Another problem is thermal shock destroying your cat from the steamWhat the worst thing that’s gonna happen? If this year I burn some of these on overnight burns when the mc isn’t ideal? My ash isn’t ideal and it’s been burning well. What’s so bad about burning wood in the 20s mc? , on hot burns,NOT slow smoldering burns
Do you prefer to burn rounds? What’s the pros and cons?Less surface area..
Cons, take longer to dry.Do you prefer to burn rounds? What’s the pros and cons?
Im new here but im beginning to wonder if there’s anything Ashful can’t do?Less surface area is more burn time.
Speaking of which, I heard Ashful was going to mill some full-load sized blocks of wood this year for a one-man longest burn time contest in 2023... should be fun!
I split all my wood...Do you prefer to burn rounds? What’s the pros and cons?
It dries better..
It may be slow to catch if the surface has a lot of ice on and in it, but once the water cooks off it'll be ok.
More chance of damage if you throw iced wood in mid-load, when the cat is still blazing, and close the bypass again right away. Not so much normally, when the load is burned down and the cat is out. Not sure if jetsam has a ceramic, anyway. But I wouldn't throw in ice wood in on a hot steel cat either.loading cold and ice covered wood is done with the bypass open. Time passes before engaging the cat. With ice, more time than without.
I’ve put at least 50 cords of wood thru four different ceramic cats over the last nine years, and every stick I load comes straight from outside to the stove, yet I have never experienced this. I suspect these horror stories are only applicable to people who make a habit of going straight from a 1000dF engaged combustor to loading cold or wet wood. If you time your loading so the cat is right at the end of its active period, just barely 500dF as I do these days, I think the risk is nearly nil. Likewise, if you go to bypass for several minutes before loading to let the cat temp drop before opening the door and stuffing it with cold wood.The worst than can happen is a chimney fire from the creosote. Another problem is thermal shock destroying your cat from the steam
Loaded stove this morning, 8 minutes in bypass, then closed bypass and got my boots and jacket on. This is what I found when I went outside, five minutes later.
OK, Whats a Beta Cat. sounds like something i need
It’s hard to tell against that ominous sky, but I was already at 99% clear emissions. No steam, just the faintest almost undetectable whiff of smoke. Humidity must have been close to 100%, it started to flurry at this time, and has continued since, despite no precipitation in the forecast.
I will admit I’m not playing fair, here. This is the B3 beta cat.
According to everyone I have talked to in the industry wet wood is a major cause of mechanical failure of ceramic catsI’ve put at least 50 cords of wood thru four different ceramic cats over the last nine years, and every stick I load comes straight from outside to the stove, yet I have never experienced this. I suspect these horror stories are only applicable to people who make a habit of going straight from a 1000dF engaged combustor to loading cold or wet wood. If you time your loading so the cat is right at the end of its active period, just barely 500dF as I do these days, I think the risk is nearly nil. Likewise, if you go to bypass for several minutes before loading to let the cat temp drop before opening the door and stuffing it with cold wood.
I suspect the only way you’re going to crumble a ceramic cat from loading cold or damp wood is to load on a hot cat and close the bypass too soon after loading. This is easily avoidable with a few minutes in bypass before and after loading, or simply timing your loads to not be fiddling with it when the cat is screaming hot.
It wouldn't matter if it was icy wood or just wet wood if you load like my neighbor, a couple splits at a time on burning loads (hot cat), and slam the bypass shut again immediately.According to everyone I have talked to in the industry wet wood is a major cause of mechanical failure of ceramic cats
Clarify for me again, maybe I'm a bit dense this morning:
If I load dry wood (no surface moisture) but is say 22% - 25% moisture into a hot stove, close door and immediately close cat, am I risking cat damage if that is a regular pattern?
I thought if the cat was active, bypass gets closed no matter what. I also though the bypass is open only in anticipation of opening the door on reload, and then only stays open till the thermometer goes active.
Even if the stove's up to temp, I burn in a new load a little before closing the bypass again. If you've got a steel cat, you don't have to worry as much, if at all, about thermal shock cracking the cat like you do with ceramic. I still burn in the load a bit, even when running the steelie.I thought if the cat was active, bypass gets closed no matter what. I also though the bypass is open only in anticipation of opening the door on reload, and then only stays open till the thermometer goes active.
I don't think too many of us are often tossing in more wood mid-load anyway. I'm usually loading after the stove has been down to coals for a while and the cat's not to temp, so I burn it in. The exception might be when it's very cold out.down under 20% and loading on an active (according to the meter) and rising temperature cat and you can shut the bypass right away.
With that unseasoned wood I would want to see the fuel load begin to burning well before engaging.
He cant work outside when temps are above 90Im new here but im beginning to wonder if there’s anything Ashful can’t do?
I can understand stand that. 90s here is miserable with high humidity typically. I think I like working in the cold better than thatHe cant work outside when temps are above 90
