2019-20 Blaze King Performance Thread Part 1 (Everything BK)
[Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK)
OK so I have taken this forums advice and done some insulating on my poured concrete basement wall. I have done the area around the stove and 10 to 12 feet beyond it each direction there is probably about 30 feet of wall that is still not insulated is it worth doing? How much heat am I losing through that poured basement wall without insulation?
What is up with that OAK?
The largest temperature differential is at the top of the foundation that is exposed to the outside air, you should insulate right to the top.
AND if that is exposed polystyrene on the walls, it must be covered with drywall or other fire rated material.
Air intake should draw outside air from no higher than the bottom of the firebox
OK I did not know that that will not be an option for me it does seem to be working fine the other day when it was cold I felt the hose that was Definitely cold from the outside air that it was pulling in should I just disable it?
OK. I did put a piece of drywall behind the stove for better fire protection. I will also cover the top part of the foundation what about the other 30 feet or so of concrete foundation wall that is farther away from the Stove how much heat and I losing from the amount slated concrete wall farther from the stove?
I will let the experts comment @bholler and @begreen. I can’t remember what the phenomenon is called but you have created a potential back draft situation.
OK thanks that was exactly what I was trying not to do I have a king on a 6 inch exterior chimney 8 inch double wall on the inside so I was trying to minimize the negative pressure effect. The house is newer and pretty airtight so I was trying to make sure I made up that air and minimize the smoke spillage
Yes you should unhook it for sure
Reactions: MissMac and Diabel
You are still loosing massive amounts of heat through the uninsulated walls.
Reactions: AlbergSteve
How is it working so far on the 6"? Also it looks like you have a surface thermometer on that doublewall pipe. If so it is pointless you need a probe to tell you anything there
Reactions: MacinJosh
I definitely will and unhook it when I get home. My probe thermometer has just showed up I’I definitely will and unhook it when I get home. My probe thermometer has just showed up From Amazon I’ll be installing it tonight. I will work on insulating the rest of the basement walls over the next few days. Overall I think it’s been working pretty good on a 6 inch I definitely get some smoke spillage on refill if there is anything but coals left in the firebox. Overall I’m very happy it burns long hot if needed. Huge improvement over my woodchuck wood furnace. Huge improvement over my woodchuck wood furnace. I do have an option of running straight to the right of that stove because it’s a walkout basement is that worth doing and how long of a run it’I do have an option of running straight to the right of that stove because it’s a walkout basement is that worth doing and how long of a run is ok?
I don’t think it matters how long the horizontal run for the OAK, as long as it remains below the bottom of the firebox
Reactions: Indiana wood
If it is exterior wall, it is very much worth doing, and so is the floor.
All exposed exterior masonry (including the floor) is pretty much just an infinite heatsink.
Interior cement walls are still heatsinking some heat down through the slab, but much less than an exterior wall where the whole vertical surface area is exposed to the earth.
Even if you don't want to do studs and insulation and drywall, just gluing 4x8 foam board up on it will help.
The floor is a stickier problem since the stove is already installed, but as a short term measure just putting rugs or carpet remnants down can help some. (Remember to honor your clearances, though.)
Re:the photo, please reconsider the HVAC intake above the stove, and remember the OAK needs to stay below the firebox for its entire run, which is usually not possible in basement installs.
Of course, unless the floor insulated with rigid foam under the slab and has a heating element in it. We don’t know.
What he said...insulate all the walls.
By code, ALL of the insulation(if it's rigid, flammable, styrene type) must be covered with a fire rated material.
Yeah, even if the thermo cuts the air, that high draft was probably pulling air in through the door gasket, around the glass, etc, and flushing some of your heat up the flue.
I go for the volume discount, and a high percentage of active ingredients. ;)
ECBP, great stuff. I’m warming up next to the stove with some OWFP.
Reactions: Woody Stover
Any of you guys running an Auber CAT probe ??
If so what temps are you seeing ??
Not on the BK. I do on my VC. I tried putting it on the BK but the probe I have is 6” and when I inserted it, it rested on the cat. I did not like it.
Any idea where I can get a 3” high temp probe?
My probe is the same as yours,,, I had a buddy make me a 2” wide X 1 1/2” H, aluminum puck, with a 3/8” hole in the center, that way I could set the probe at 2”, held in place with hi temp silicone between the puck and the probe..
Then I have a piece of 1/8” hi temp gasket material with a hole in the center between the puck and stovetop..
Works great..
Clear as mud ??
