I don't often rum much below half swoosh. With good dry fuel and some wind I can run 1/3 swoosh, but my insulation envelope is so good on my house there isn't much point, I might as well let it burn out and light up again when the temp drops again.
Oooo, don't let the other BK guys hear you saying that; To some of them, starting a fire is something to be avoided at all costs. I guess some are just slow to master the art of the easy start.
I meant as far as just letting my stoves go out because heat demand is so low. I don't chase burn times, I just heat the house and don't worry about how long the stove burns for. My house just doesn't need much heat.
Exactly; The whole long, low burn thing is pretty much a red herring, in my book.
I read about people taking 20 - 30 minutes to get to active cat, and that's just way too long for me, if you have dry wood and reliable draft. Maybe some setups take that long
Mine takes 20 - 30, but my stove has more thermal mass to get up to heat, with the stone box, so that's a draw-back..
We call that chasing the dragon
You used to call it "chasing the heat curve." When I hear "chasing the dragon," I think of trying to get my BIL's basement stove, a 1979 VC Resolute III, to burn clean.
I have never had a failed light-off at any flue probe temp > 500dF....Usually the combustor will be glowing within 2 minutes of closing the bypass with flue probe at 500dF....see if you get instant light-off, as I typically see. If not, try 100dF higher... it will still be long before the cat probe shows active.
I like the instant light-off. I don't have an accurate cat probe yet so I go by flue/stove top temps, and looking in the box to see how much wood is involved, to tell me when to close the bypass.
If you wanna "go low" as far as stove/flue temps, keep pumping some flame heat to it, to kick off that cat.
it’s been years since I’ve cared enough to go outside and look at my stack....you honestly couldn’t find something I care less about. If the cat is active, that’s the most I can do, that’s what I can control. As to whether that active cat is able to keep the plume clear, that is up to the design of the stove.
Even though you sometimes expound on the minutia of stove operation, that statement indicates that you are unworthy of the moniker "Stove Nerd."
True stove nerds, like Poiny, are always fine-tuning every aspect of the burn and emissions, in the pursuit of perfection.
QUOTE]To me, acting responsibly is installing the best appliance available, and
then operating it properly. Maintaining an active cat for the maximum possible period is doing that, IMO. Would you rather I run longer in bypass, maximizing my particulate output for a longer period?
[/QUOTE]OK, maybe there's hope for you to earn Stove Nerd status, after all.
The way I see it, there's a balance when the bypass is open. I want enough flame to eat a lot of smoke, yet not have the air open so far that I'm losing too much flame heat up the flue..I want that heat absorbed by the top re-burn area of the stove so I can hopefully light the cat quicker. And if you get right parts of the load burning early, that can reduce startup emissions. I load E-W so I can pull the coals up and keep the flame mainly on the front few splits, while seating some big split in the back with no coals under them so that they don't smoke early, where that smoke would go straight to the open bypass.
For the regulated burners among us, the law specifies what plume opacity we can have.
Another factor in emissions/opacity is how much creo we are burning off the inside of the box when we have big flames, firing up a new load..creo that was deposited during the previous low burn. You obviously don't get a lot of creo in the box, since you run a hot fire most of the time.
But I remember one post by a BK burner where he asked why he was seeing smoke early in the burn, after his cat was glowing. This
could be from having the air open with a lot of wood gassing, where the cat couldn't catch it all. But in this case, he was smelling acrid creo smoke. I surmise that this is box-creo burning off, and the cat can't easily catch that dense stuff either. That makes me question how clean these cat stoves really burn. When I mentioned this before, BKVP replied that the tests were done on "used" stoves, not brand new ones. But were those used stoves filled with gooey creo?
My stove doesn't have gooey creo in the box, but the dry stuff also burns off with a high fire..I can smell it outside. I guess I should do more maintenance in scraping crusty creo off the inside of the box when I get a chance to let the stove go out. This should also have the added benefit of allowing radiant flame heat to get the stove up to temp faster, and allowing more heat to transfer through into the room when cruising.
Good luck trying to do that on a BK, with the inner baffles covering the walls of the firebox.
