So hot reload. Clearly in the tail end of the burn, check, see previous post. Shut down convection loop bringing cold air to stove room check. Shut down convection deck fans, check. Combustor probe within a couple or three needle widths of the magic tick mark, check. Wait two minutes for air flow convection loop down the hall to wallow like soft jello and then disintegrate, check.
All of this to avoid giving the combustor a facefull of cold air. The total stove is raging hot, I just burnt down a full load of good dry spruce in about four hours. I can't stand within about six inches of the stove without the hair on my legs getting extra curly.
Have a quick snack, check. Stand between the stove and the hallway to the bedrooms, confirm convection loop is stopped, check.
Flip big lever to bypass, check. Stuff it like a holiday turkey
Run it with the door cracked until the chimney starts huffing whoo-fuh whoo-fuh, about ten seconds. Close the loading door. Get the load charred good by waiting for a slow count to 60 before flipping the big lever. After slow count to sixty, channel Jean Luc Picard, engage, full swoosh.
Run that 25 minutes with fuel at 13-14% MC and get to here:
![20191204_220429.jpg 20191204_220429.jpg](https://www.hearth.com/talk/data/attachments/252/252900-695063c5ed061aa842270821b29b6bda.jpg)
Now the load is baked and ready to be controlled in a predictable manner. I could turn all the fans back on and start pulling BTUs off that thing like cases of beer off a UHaul truck, or I can turn it down and coast it for hours and hours and hours. Either way the flue gas probe will drop pretty quick. I turned this load down to 5/8 swoosh and my flue gas probe is showing a touch under 600dF in just a couple minutes. Another 3-5 minutes I will pop it down to somewhere between 3/8 and 1/2 swoosh and it should settle in right around 400dF flue gas temp. The combustor probe will start coasting down over the burn. I should be able to do another active cat hot reload 8-10 hours from now no problem.
I make an effort to not be dogmatic about disputable stuff. I am personally a firm believer in running the stove on high for thirty minutes ( at least 25 minutes with dry fuel at 12-16%MC ) before trying to turn it down for a long slow burn. I know folks do it all the time and don't have any problem. I also like running on high for 30 (25 with dry fuel) minutes before restarting the convection deck fans and the box fan down the hall on the floor. At the end of the 30 (25 dry) burn on high I need long pants to stand within 12" of the stove, but my burns are approximately as predictable as gravity.
If you are new to this stuff and your burns aren't consistently predictable and your fuel is at 17% MC or higher try tuning out the folks getting away with RTFM errors for one week and see if suddenly your BK stove is about as dependable as an anvil.
I turned the thermostatic control valve (the throttle dang it) from 5/8 to 7/16 after 3-5 minutes at 5/8. I have no visible flame, black box, flue gas probe is showing 450dF and dropping. If tomorrow was Saturday and I could sleep in I could probably do a hot reload (on an active combustor) 16 hours from now.
