It sure is! Gas powered Briggs motor.Huh, is that a kinetic splitter? How is it powered?
He might get a tan there..we have relocated the diaper changing station
I’ve been using my little tractor to help move around firewood too. It sure is handy
Draft should be measured on hi/full burn, .05 is ideal...Update on the icing....
It's worse than initially realized. After only a few months we had a good bucket + of creosote. Not at the end of the flue, but around the 1st and 2nd seam down. My dad had put a "cap" on top of the rain cap in order to prevent rain from coming in, the original cap design sucked. I think that his modification negatively affected draft too much. So we've taken the whole cap off, going to run naked.
Second thing is the seal around the bypass door was definitely compromised. I've fixed it up and it should be good now.
Third I have my suspicions about the wood MC, but haven't been able to test yet.
On the good news is the OAK was perfectly fine. We fired it up after cleaning and removing the cap, and the draft was way stronger. We were getting spillage issues during reloads so I have a feeling that was a big part of the issue.
Going to test the wood and draft, and go from there.
A couple more questions:
- What is the spec for wood MC? Manual says 20%. I believe reading on here 22% is ok but below 20% is ideal?
- What about draft for a Princess Ultra. .05" hg on high?
This is correct. Max recommended is 0.06" water column, and ideal is on that high side of that, 0.05" water column. If you're running a whole lot over that, as I was on one chimney, a key damper and magnehelic are the choice tools.I think it’s inches of water, not mercury. There’s a range that’s allowable.
Come here and see how far you get with a wheelbarrow stacked that high with Black Locust..Do you ever load your wheelbarrow
I have great luck with these guys https://www.hechlers.com/ Even called them on the phone and they were very nice and helpful, shipped everything very fast, prices are good and took great care to wrap everything in bubble stuff to protect the contents.Where do you order door seals and cat seals and extra parts right from BK
I just did the "big" service on mine, engine oil, hydro oil, all new filters, front axle oil and tighten the fan belt.I’ve been using my little tractor to help move around firewood too. It sure is handy.
Theres nothing wrong with doing that, just make sure theres no nails and it non treated as you already stated. The T-stat will protect the stove from over firing, BK's love a mix of hard and soft woods, especially when turned down to boring mode.Does anyone burn non pressure treated lumber in their stoves?I threw in a few scrap 2x4s with some oak yesterday and the cat seemed to love them.I think I have seen BKVP suggest to people in the past that this is a good way to check if the cat is working if you had questionable wet wood.Just not sure if this is something you can do long term because basic research gives mixed opinions.
Thats what it seems like and yes on making sure there is no metal in them.I have used those compressed saw dust bricks at times mixed in but the scraps seemed to be a better burn.One site online warns against burning them mostly because of a chance of saltwater exposure but that seems unlikely to me.Theres nothing wrong with doing that, just make sure theres no nails and it non treated as you already stated. The T-stat will protect the stove from over firing, BK's love a mix of hard and soft woods, especially when turned down to boring mode.
Bk chow!
Do you ever load your wheelbarrow and then think about how many days it will keep you warm? This is all Doug fir, having a woodshed is really really nice. No tarps to fuss with.
+ 2I have great luck with these guys https://www.hechlers.com/ Even called them on the phone and they were very nice and helpful, shipped everything very fast, prices are good and took great care to wrap everything in bubble stuff to protect the contents.
yes for the most part. 3:00 give or take on the dial usually and fans on, off, but usually on a timer. i found that a cheap timer set to turn the fan on and off on 30 min or longer interval works great. my fans, even when on low, if left on all the time severely shorten my burn times.
i am going to wire a temperature activated switch (a stat) for the fan that is across the room. temp gets below 70? fans kick on. like a furnace or any other HVAC product.
But remember that most of the time the cat still active. It is just the fan blowing on the probe and makes it look like it is inactive. Once the fans are shut, the probe climb back into the active zone.It's possible you'll stall the cat.
I used to have my fan on a timer to hit on high for 15-30 minutes every hour but personally found that just running the fan on low or a bit higher than low works just as well.
With a low burn setting and the the fan on high for two hours I think it'll be below active by the time you get to it.Maybe 30 minutes before would work.
Damn now I'm feeling bad, I could burn that wheel barrow in a day heating this place with my Summit![]()
So that was 30 big splits. I reload every 24 hours 95% of the time and can only fit 6-7 of those splits into the bk firebox. So that’s 4-5 days of heat in my house. Not bad for softwood.
Now I “could” burn it faster in the fire pit or in my noncat stove in the shop burning hot. That noncat bugger fits about 8 splits and on a three hour reload schedule I could burn it all in one day. It’s really a shame to spend the fuel like that though.
Three things going on here, the bk can just sip wood when your chosen burn rate is low which isn’t fair to compare with burning hotter in a noncat because it doesn’t turn down as low and because I want high output where my noncat lives.
I could make due with a tiny Woodstock stove in my home if I could tolerate the short burn times resulting from the correspondingly small fuel tank (firebox). Bigger fuel tank on the bk and way smaller installation clearances.
Ya wow that’s pretty impressive that your using that little wood, but how many sq ft are you heating? We’re in similar climates, I’m heating 2400ft from the ground floor. I want to try a princess badly, just hoping to pick up a nice used one as I am nervous of performance on my up and out chimney setup(works perfect with the summit). That way if it doesn’t work I can send it down the road without loosing any $$. I wouldn’t expect 24hr burns with my heat load but a 12 hr reload schedule with the stove making meaningful heat would be amazing to me!
I'm pretty sure I asked the same question a few years ago, whether the cat was really inactive or the fan blowing on the thermometer made it appear that way.Maybe someone can chime in because it might have even been BKVP.The way I was told was that yes the cat goes inactive, not just a false appearance of that.I guess it really wont matter too much in your situation either way.But remember that most of the time the cat still active. It is just the fan blowing on the probe and makes it look like it is inactive. Once the fans are shut, the probe climb back into the active zone.
