I would think it would depend on the fan speed/heat transfer as to how much it would effect wood usage.
I think you can tell the difference by looking at the flue exhaust (until late in the burn, anyway)- if you see any smoke, the cat is off the job.
This may sometimes be the case, but it is not always true. I have seen smoke with an active cat, many times, on five different catalytic stoves. There is no guarantee you will have no smoke, just because the cat is active, nor does the presence of smoke indicate the cat has dropped.
I would imagine a combination of many things we just wouldn't understand or can control, seasoned wood that may have a moisture bubble, different outside pressures from subtle wind shifts that may extract more heat from the stove before the t-stat can open and heat the fire box fully again, under performing cat, heavy off gassing firewood.. many many things, I know this much, I have a much cleaner burn with this stove vs my old us stove.So, why is that?
The highest I ever go on my fan is 3/4 wide open, but most of the time on the lower than half side, I feel with that combination I get better heat extraction from the stove top (have convection deck) and I'm able to keep the t-stat just a click above half way and still maintain long burns on the coldest of days.I only run my fan on low,
There’s no lab data. I know first hand my burn times are a bit shorter when using the fans. But considering all the variables that influence actual burn times, I could lay all the reduction on the use of the fans.Does BK have any data about how much using fan would affect wood consumption? Is it as dramatic as jetsam experienced like %50 difference?
Ya I'm not running fans, this time of year it's all about keeping the chill out not really heating. So a nice dark window is all I was going for...There’s no lab data. I know first hand my burn times are a bit shorter when using the fans. But considering all the variables that influence actual burn times, I could lay all the reduction on the use of the fans.
Strictly anecdotal findings from fellow users may most helpful.
I dunno if My input will help you, but here it goes..If anyone has a King how low can you run your t-stat I know it will vary but I'm trying to get an idea... Thanks...
Blaze King King Parlor Wood Stove
As per BKVP the testing/certification is done 30" from stove top, and you check it at full burn..What is the right way to measure the draft on a BK? How high on the stack do you insert the tubing? At what point of the burn is the right time of measure it as for BK specs? I ask cause I will like to measure the draft on my taller setup.
There is a limited amount of fuel the combustor can process, for a given rate of flow through it. At some points during the burn, your wood is off-gassing more fuel than at other times.So, why is that? On both of my stoves (different animals) I can have a full burn with zero smoke/plume and in the next reload (same wood pile splits) occasional (15min) visible smoke in the middle of the burn with cat very active.
Before I got the BK I thought...sure it has to be the loved here (bholler!) VC and it’s issues. But now on occasion I see it with the new Princess as well.
I’m in the same situation. But I also find that I can just about stall it if I dial down to 0.06” WC (essentially completely closed key damper) during bypass mode. We could almost use a whole other thread to discuss the world of running key dampers and draft gauges on BK’s.My stack is about 35 ' so I have way more draft than a shorter stack, last year I added a key damper, this year I added another key damper, so now I have two of em, and I'm still above what BK recommends as far as draft..
I've cut my draft from .23-.26, to .08-.13 with a pair if dampers..
I prefer the Magnehelic, it’s an old standard in the HVAC industry. There are many other types of manometer on the market, but I believe the Magnehelic is the best option, for this application.What is the right way to measure the draft on a BK? How high on the stack do you insert the tubing? At what point of the burn is the right time of measure it as for BK specs? I ask cause I will like to measure the draft on my taller setup.
... for the same thermostat setting? I still don’t understand why lowering the thermostat to compensate for the effect the fan introduces to the thermostat, doesn’t at least mostly compensate for having it running.My experience is running the fan kit wide open on an AF 30 cuts the total burn time by about half, but it also gets twice as many BTUs into the envelope. Or the same number of BTUs in half the time...
The three variables I recognize are 1) outdoor ambient, colder air = more draft -> faster burn, 2) thermostat setting on the stove, higher setting = faster burn and 3) fan use, higher fan setting = faster burn.
Of course, you could then argue that there’s no reason to run the fans if you’re just going to be cranking the stove down lower, but I’m talking principles here. The fan cools the thermostat, which causes it to open wider, for a given setting. Turning the knob lower should compensate, the way the thermostat works.
Agreed, but that doesn't scale down to minimum burn settings. At the lowest burn you can do without the cat going out, turning the thermostat down and the fan on just puts the cat out.
I keep harping on this minimum burn thing because that's where my stove runs for 2-3 months of the year.![]()
I'm not an experience burner but this info is very helpful. I was under the impression I might be able to run the stove on "low" for 16-24 hours but my interpretation of low was both low-thermostat and low-fans. It is just good to know, because it is not spelled out in the manual. I would have been frustrated if I had tried for long burns and never got them because I was always running the fans.
Granted, it is relative to BK stoves. 8-12 hour burns with fans on is still plenty for me.
I would add initial stove state and fuel MC to the list, but draft/thermostat/fan are all bigger variables.
