There is a shoulder washer that goes through the assembly. You said it felt loose and now it won't move?
No!I found these in garage left from previous owner. Should I use them to give me lubrication to the handle?View attachment 237403
Check the set screw on the knob and make sure that it is actually turning the shaft. Does the knob rotate freely or does it stop turning normally?
Should I use WD-40 or some lubricant?
Water Dispersant #40 is not a lubricant. It was designed to prevent rusting of items stored outside for short term. Use a high temp anti seize.
View attachment 237390View attachment 237391
I took the pictures of the door handle in the morning.
It is so stiff. I could hardly open and close the door. I loosened the marked hex nut but didn’t help. I dont see any creosote build up or anything that could make it stiff.
Hard to say, it's always hard to heat the upstairs from the basement. Need more info on the layout , stair location and stove location. I'm heating 2400 feet but it's all on one level and relatively open plan.Random question, but is a princess gonna be enough stove for my 2400sf split level home? Stove will be in basement
Just sent a message to my dealer and hopefully this won't be a big issue, but my stove keeps having an issue where it won't turn down.
Here is the the stat setting:
View attachment 237393and this is the firebox:View attachment 237394
With the fan on as high as it goes, this is the cat temp:
It stays like this for about 30-60 minutes before it starts to calm down. Otherwise it just rages. There is no clinking sound on the turn down like normal, and no whistling noise. It is like the knob does nothing. Moving it up or down does not change the fire intensity.
Please let me know if there is anything I can do, thank you.
The upstairs is a fairly open layout. Downstairs is fairly sectioned off with the stove being located in the mechanical room roughly 15’ from the stairway. Also the stairway is open with no doors.Hard to say, it's always hard to heat the upstairs from the basement. Need more info on the layout , stair location and stove location. I'm heating 2400 feet but it's all on one level and relatively open plan.
Currently I am running a old Kuuma 1 wood furnace, just running it wild as I didn’t want to put it back into the ductwork after I had my AC coil installed. It works ok once the basement heats up but the burn times are garbage, roughly 4 hours on a full load. And of course it’s a pain dealing with the soot buildup in the stove pipe, hence the desire for a BKThe upstairs is a fairly open layout. Downstairs is fairly sectioned off with the stove being located in the mechanical room roughly 15’ from the stairway. Also the stairway is open with no doors.
Yes, definitely not planning to use as primary but more for supplemental and I enjoy the wood heat especially in the fall and springI would guess not enough for 100% of your heat, especially not if it is the insert model, but if you're willing to run your furnace when the stove can't quite keep up then the princess could be a good stove.
I burned almost a pickup load of oak between New Year’s Eve and day. Iron range weather can be brutal. How often would you say you had to load? 4-5 hours? How many splits at a time?MN Nice
I have a princess in my 2500 square feet northern Minnesota home. I have a fairly open floor plan and the princess gets the job done when it's above zero. Once it gets below zero if I shut my bedrooms and bathroom door it is comfortable in the living room area. When it was -24 below on New years eve I did manage to get the house to 76 degrees but it took the best quality oak that I have been saving. I can get by when it's -30 but I have to add wood often and run the stove wide open. I think you would lose some heat with a basement install. On most days I can load the stove at 7:00 AM and come home at 4:00 to a bed of coals. The house is cooling off but it warms up fairly quickly after a reload.
Oh installed new gasket. It appeared the ashford only has the gasket on the bottom, is that correct? Anyway I put a new one all the way around.
Maybe some veteran wood burners could answer this one. What would happen if a King stove was hooked up to a 6 inch flue? I understand the outcome would be different in each setup. Is not getting a good enough draft the biggest problem or is their a safety issue? I'm sure someone has done it and I'm just curious. I have a homemade wood stove in my shop and I'm willing to bet it has at least a 5 cubic foot interior. It will handle a 25 inch log easy. The stove is hooked up to a 6 inch flue. I've only fired it up a few times but it ran great on 6 inch flue and a 20 foot chimney.
And no i'm considering a King in my house. But it would be nice.
