I think i had part of a pile that was under seasoned. everything has been seasoned for over a year, but i did find some spruce that was still pretty heavy. Back to maple, aspen, and cedar that was all less than 12%Son, reckless has helped many of us here... a good help.
Dobish, I think your wood might be a bit underseasoned .
Holy smokes. I leave town for a week and a half and the forum comes to life. Good to see everyone is burning good and figuring out their issues. Son, what did you ever end up doing about a cat probe?
By the way I was in Arizona and California ripping dirt bikes in 80 degree sunny weather... definitely did not suck.
Eeeee I'm melting I'm melting.
And with it in the cabinet there’s no way to get to the back of the stove?I can see a small difference but still the fire is still going quite strong. There is no way can I stop it by just closing the primary.
Any indication as to why it burnt up on you? I feel like I’m on season 3 or 4 on my probe and running just fine. (Knock on wood).After almost three season of use my K thermocouple is toast!
Spoke with Auber today and they confirmed that its behaviour is very indicative of toast! The AT100 is ok.
At about 900 it goes to EEEEE (error I suppose). I ordered a new one (19.00). I tell you running the stove on flue pipe temp and stove griddle temps and its sounds is sooooo weird. But since I know the stove so well I am doing ok.
Trust me, running these stoves with only a stovetop thermo. is a definitive death sentence in other words, sure and premature stove failure.
Try leaving a couple inches of ash in the bottom of the stove. Also replace you ash pan gasket and your griddle gasket. And while you are at it, your glass gasket as well.
The griddle is the top loader. That should come off easy in the open position. Replace the gasket in the groove on the actual stove top. A lot of us are fans of just using regular 5/16 graphite gasket rope for this. There should be gasket on the door of the ash pan. You stated you replaced the door gasket, but did you replace the glass gasket as well? This is a very small gasket and turns to dust in a few years. Post some pics of your stove also of the ash pan door.Thanks for the input so far,
No I dont think so, I can remove the bottom heatplate and by usint the phone almost see a little bit of the back but thats about it. I always leave quite a lot of ash before loading the stove, only emptying the ashpan itself.
Is there gasket to the ash pan on these? From what I can tell its just slided into metalframes in the stove, I dont think it would need any gasketing?
Not sure how I can replace the griddlegasket either, it seems to be mounted on the back of the upper firewall only accessible with the bypass open so I guess it would need to remove the cabinet and back of the stove to access that in an easy way.
I have replaced the gaskets on the door, it didnt change the situation at all so the leak must be somewhere else I think. I think I will try the topdoor gasket next just to be sure but it seems to be really tight.
