Doc C
When the stove is cold, make sure your cat probe thermometer is accurate. It shouldn’t be pointed below the last mark under inactive. If it’s under the mark it needs calibration.
Already done. Thanks
Did a little experiment today. It's been about 13C all day today and I maybe half loaded the stove this morning. At noon I turned the stat to 12 o'clock and "rode the hole" for six hours. Just got back, got a big bed of coals and the cat is still active and most of the house is 23-25C.
Riding the hole at least with Blaze king means turning the damper all the way down?
Yep.Riding the hole at least with Blaze king means turning the damper all the way down?
I went with the princess insert and I am not looking back. I started my journey with BK back in January of this year lined my existing chimney with an insulated liner. First thing I noticed was how much easier it is to start a fire. Another thing is how much control you have over the burn, I just can't imagine a more reliable way to control a natural wood burning fire. Just one warning though...this is starting to become an obsession of mine. Check out my posts, not long ago I was on the fence to!I'm not convinced either way, that is why I'm here. I've basically decided I would like to buy a BK ... and if all of you say that a cat is just fine and does not require a ton of maintenance I am willing to go with a cat. Now to narrow down a model that is right for my house ... Princess, Ashford 30 or maybe the Ashford 20?
I emailed BK directly about this last week, and they are offered as non-cat. My friend that recommended the BK Princess, has a non-cat one. Here is the email response that I received from BK about this:
"Thank you for considering Blaze King.
Only the Princess and King models are offered as a Non-Catalytic. The Non-Catalytic models come with a Thermostat that will regulate the heat output, but the Thermometer is not included (Thermometer tells you when the Catalytic component is Active). All our other models, such as Ashford, Chinook, and Sirocco are Catalytic models. Unfortunately we do not have conversions for the Catalytic Models.
You can check out all the models on our website www.blazeking.com.
Our dealers are great with an question as well, closest Dealer to you would be Anola Building Centre (204) 866-2815. We have a couple dealers in Winnipeg as well if you prefer.
Jessica Logie
Dealer Support
Blaze King Industries Inc
Valley Comfort Systems"
She was pointing out the non cat models have a thermostat, not a thermeter. Only the cat models have both.How can it be a non-catalytic model if a thermometer informs you that the Catalytic component is Active? How does a non-catalytic model have catalytic components? The two comments make the email a bit confusing; I suggest you get clarification.
Our stove have been awesome for us for the first two seasons (cat type). This year was not what I would call a short or warm winter in northern Canada. What would be a normal 17 to 18 cord season on our old stove has reduced to a 12 cord season with this stove. It is a different heat not the same as the old were you keep rifling wood in. You load it and forget it and it will chug along with lower heat out put, very controllable. It is an awesome piece of technology and so far not one complaint.
Regards
How far north are you? The most wood I ever burnt was 5 cords with my old smoke dragon. Looking at 3 cords this year with my new stove.This year was not what I would call a short or warm winter in northern Canada. What would be a normal 17 to 18 cord season on our old stove has reduced to a 12 cord season with this stove.
In Quebec some people know what a full cord of wood is but everything is calculated in Face cord.
Take into account that riding the hole doesn't work for everybody. it is dependable on proper draft, outside temp,heat needed, etc. A good charr on reload helps a lot to run the hole but still depend on those variable mentioned before. I can run the hole on the taller stack most of the time but the shorter stack the lowest i go on it is around 1:30 to 2 o'clock and the cat stays active with outside temp up to low 70s.Riding the hole at least with Blaze king means turning the damper all the way down?
That's good. My shorter is around/almost 19' with the cap. The other around 24' cause it goes thru the two story part of the house. With outside temp of 55 df and under, no worries to run the hole on the shorter. Anything above that temp and have to give a little more air. the taller can stays on the hole all the time.My stove used to be like that, but with a new cat I can go all the way down to the stop! So much nicer for shoulder season.
I have a short stack too.
Yep, that's why I thought I'd give it a go, just to see what happened. It's getting warm out now but I still want the house at 21C. Thought I'd try and cruise the stove on minimum without cooking us out, seemed to work. And I'm NOT turning on the electric heat!Take into account that riding the hole doesn't work for everybody. it is dependable on proper draft, outside temp,heat needed, etc. A good charr on reload helps a lot to run the hole but still depend on those variable mentioned before. I can run the hole on the taller stack most of the time but the shorter stack the lowest i go on it is around 1:30 to 2 o'clock and the cat stays active with outside temp up to low 70s.
