LOL. Switch locations with the Princess and 30NC and report back how it performs when pushed as hard to raise temps a big workshop space.12 hour reloads when it’s cold but those noncats only last 3 hours when they are being run hard. Weird. Where does all the wood go?
1963 sears home kit in the high peaks of the adirondacks takes some btu's to keep the mrs. happy.
Excellent explanation, very enlightening. Hadn't even considered the role of regulations compliance. I bet it is hard to pass with thermostat control, particularly mechanical.Because it’s extremely difficult to pass the epa test with a thermostat that is controlled by the heat the stove is producing. The epa test has highly regulated guidelines, and costs tons of money for testing. Each fail cost money and time, it could easily put a manufacturer out of business. Big manufacturers already have their own technology that they’ve sunk tons of money into, switching to the thermostat would be like starting over completely. It’s BKs thing, has been for 40 years or more.
Right up the chimney! I really DON'T like how much I heat the atmosphere right above the house. It's a nice clean heat, though. And the pipe does stay clean.12 hour reloads when it’s cold but those noncats only last 3 hours when they are being run hard. Weird. Where does all the wood go?
On the minus column is initial expense, which can probably be justified, and the ongoing expense of the cat. The periodic cost of replacing the cat is the deal breaker for me. It's not lost on me that the company needs to make money, and recurring consumables is one of the best business models going.
I spend more than that on beer and stupid stuff.
Dutchwest cat? What didn't you like about it? I've had the little 2460 for about 17 years, got it used for 350 when it was 5 yrs. old and it served me well for 10 more yrs, until I upgraded. I've still got it around as backup. My SIL has the same stove. They both could use a teardown for new seam cement (hers more than mine for some reason) but other than that we've never had any problems. A stove shop here picked the line back up for a couple of years, several years ago. They were going for 1500, pretty cheap for a cat stove. Sure, the castings are thin and can warp, and if you abuse it you are gonna have problems, but whaddya want for that kind of money? Then there's that dinky window. But it's the stove that got me hooked on the ash grate which is now one of my must-haves in any stove I'd consider. For a few years now, the Woodstock steel hybrids look to me like the best deal in the cat realm.My DW went right where it belongs, the scrap yard
That's where I think a lot of the fanboy-ism comes from..first-time cat stove owners. If you came from a tube stoves or an old smoke-blower stove from the 70s, sure, you're gonna think your new BK is the greatest thing since sliced bread. If you've been burning cats for many years, as I have, I don't think you will find a BK nearly as amazing. Now in your situation, having that thermostat in your greenhouse would be great as far as a hands-off, foolproof setup. Good choice for you.most of us >have ran and owned< a myriad of non-cat stoves with their short burn times, crazy emissions, and ridiculous use of wood per season.
Begreen's comments didn't come off as "jabs" to me at all, not sure how you came up with that? You're another guy who never really had a decent cat stove before, just those downdraft Jotuls that self-destructed multiple times and were a "royal" pain in the arse from a control standpoint, according to the posts of yours that we read here. It's understandable that you're dumbfounded by how easy running a good cat stove can be.@begreen makes one little jab, as one who has never even owned a BK,...He makes a good point, in that these stoves aren't magic, we still need to reload more often when it gets cold. Of course, he is missing a lot too. Again, he's never owned one, but he is having a lot of fun with you.
On the flip side, I am having an issue with one of my cat stoves. I have a chimney that provides 3x - 4x the allowable maximum draft. It has caused me some issues with clogging combustors.
Of all the factors that go into a stove choice, this is the one, for my money, that most heavily favors the bk arrangement.
Eventually you fall into a rhythm with the more frequent reloads of tube stoves, so that stopped bothering me after the first season. Sending so much heat up the chimney will never stop bothering me.
Of all the stoves I’ve had, the Dutchwest was the least impressive stove. They are pretty durable, I’ll say that. I got a good deal on it and was able to make a little money fortunately.Dutchwest cat? What didn't you like about it? I've had the little 2460 for about 17 years, got it used for 350 when it was 5 yrs. old and it served me well for 10 more yrs, until I upgraded. I've still got it around as backup
three stoves? how much wood are you going through in a year? If you were running three Jotul Oslo's, that would be a full time job.
You guys crack me up.
Good points. $97 per year in consumables to keep the heat in the house would be a small price to pay. I'm on my third $75 vermiculite baffle in three years. They are fragile, and even though we don't touch them, they crack in half, I'm guessing from too rapid temp change. So far, all covered under warranty, but that's over now. This was an unexpected expense that is a definite minus in the tube stove column.On the recurring costs thing, blaze king doesn’t make cats. You go to amazon and buy a new one no more than once per 2 years (10000 hours) from a vendor. I don’t think bk makes nearly as much money from parts as say Englander with the very expensive baffle boards and gaskets or the pellet stove line.
The cat for my princess is 186$ shipped. That amount of money is easily recovered by the wood savings in part of just one year of burning.
I burn my Englander nc30 hard to heat my workshop and I strip as much heat as I feel possible from a long single wall flue pipe but when I go outside I see that huge plume of clear exhaust and how much energy is puking right up the stack in order to be “clean” enough for epa. It’s an effective technology but wasteful.
My home is also from 1963 and when we’re in single digit temperatures I have to turn the princess to 50%. My reloads are then more often than every 24 hours but it is important to note that I never need high output. Long burn times mean you can keep your house warm so you don’t need to run these things hard to catch up. Keeping the house warm is also possible with a noncat if you are there to load it several times per day. The whole recovering thing is why people think they need so much stove power.
I wish I knew what was causing it. Perhaps it gets wet when the stove isn't running because a stiff horizontal/diagonal rain, followed up quick heat up of the stove. I lost a pizza stone in my grill like that last fall. CRACK! But, I don't want to pollute the pristine BK-only nature of this thread...Whoa! I’m very careful not to damage the baffle in my nc30 but I load it to the roof! The price to replace the baffle boards is way more than 75$ now since the recent increase from Englander. If I were you I would really try to fix the cause. You should be able to get many years from the boards.
Yeah, I think they are pretty finicky..different animal than the cat stove, for sure.It wasnt a cat stove, it was one of those downdraft stoves
Not exactly a "superstar"Of all the stoves I’ve had, the Dutchwest was the least impressive stove. They are pretty durable, I’ll say that. I got a good deal on it and was able to make a little money fortunately.
Ya, pretty sure he's not getting 12 hrs. with the air wide open, heheh.LOL. Switch locations with the Princess and 30NC and report back how it performs when pushed as hard to raise temps a big workshop space.
Even if you have to replace the cat every two years, no big deal. I spend more than that on beer and stupid stuff.
