Sounds like you badly need to upgrade to a king!
PS sell me the princess
Edit to here they call that style of house a cabover. Usually it's a bedroom above the garage and they're notorious for being colder than the rest of the house. The fix is to spray foam the ceiling of the garage with 2 part, and maybe double insulate any north or west facing walls in the bedroom.
in the ceiling. Well, it’s a pellet stove... of course it’s struggling. Definitely don’t compare woodstove btus to a pellet stove. Night and day difference.
I don’t miss mine either. Not one bit!I don't miss the pellet stove we had in our house in town.
I used to have a constant issue with this, since my heat loss is very high. My solution was to use an ash rake to plow the ashes under and to the rear of the stove, which causes the coals to rise to the top. Rake the coals forward, and throw just a single split or two on top. Run the stove on high, which will cause the exposed coals to burn down rapidly, while those one or two splits keep the cat working and heat output up.The issues with high burn comes down to the need for 100% heat output and oak leaves coals at full burn. The coals would heat the house at 20f alone, but when it’s really cold they take up fire box space.
You asked for it! Picture time Ashful!ashful, do you really have ll those stoves and fireplaces. what are you heating, an old castle?
Ohhhhh a bigger freestanding stove....ummmmm. Not on a 6" flue, but then again my stack at home is 8" already. ummmm.
New test unit at your home? Should I hold off on a buying a princess ultra or just go ahead?
Yes, two fireplaces, each with a BK Ashford 30.1. They do an awesome job, really only limited by my willingness to keep them fed.You asked for it! Picture time Ashful!
![[Hearth.com] 2017-18 Blaze King Performance Thread PART 2 (Everything BK) [Hearth.com] 2017-18 Blaze King Performance Thread PART 2 (Everything BK)](https://www.hearth.com/talk/data/attachments/221/221182-65241e0512fad4f55764f45309019c36.jpg?hash=5KPiDEcia_)
![[Hearth.com] 2017-18 Blaze King Performance Thread PART 2 (Everything BK) [Hearth.com] 2017-18 Blaze King Performance Thread PART 2 (Everything BK)](https://www.hearth.com/talk/data/attachments/221/221186-f81a256951be9587226e568b371d0c66.jpg?hash=OCi1RbT30b)
View attachment 221154 View attachment 221155
Ignore that Jotul Firelight in the first photo, I just haven't gotten 'round to taking a newer photo with the Ashford in that fireplace.
House is essentially three smaller houses slammed together. The 1770's part seems to be built over and around an earlier house that was built on this site about 40 years earlier. The 1890's part is a bit of an insulatin nightmare (balloon framing with blown-in polystyrene), which is going to be mostly torn down and rebuilt in the relatively near future.
View attachment 221156 View attachment 221159
I would lean towards more of look thing, if it were for heating, the ceilings would be much lowerSo what’s the deal with the huge fireplaces? Was it because they needed the heat because of no or poor insulation so they just packed it full of wood to get the most heat out of it? Or was it just a look type thing?
Lopi Rockport
Blaze King Ashford 25
New test unit at your home? Call it the Emporer
hey there Mr BKVP dude. I take it you have something to do with Blaze King?
Lopi Rockport
That just says the 2.85 for all models.All the Princess Info is right here:
(broken link removed to http://www.blazeking.com/EN/wood-princess.html)
@ratsrepus, the belly of the Ashford is probably 3 inches below door sill. I understand the Princess is deeper, but I’m plenty happy with my Ashfords.
The Ashford is slightly smaller too, but only 7%, I wouldn’t let that be a factor.[/QUOT
Better looking stove too isn't it? hows those cast panels on the sides work. maybe you could post a close up pic, thanks.
