Looking for advice:
1300 sq ft house in winnipeg mb where it cam hit -30c. Mostly burn debarked American elm and ash (super dense, not sure if it's green or black ash). A wee bit of pine. Flue is 12 ft straight up. Air intake from outside.
Currently have a non cat stove. Wood pro ts2500. Wanting longer burn times and more stable temps. The box on this thing is designed poorly. With a bed of coal you can get one 10" wide 20" long split in there and that's it. Over night it's usually too warm in the living room (25 or so) but cools off quickly as the night moves on. Mornings require a restart which can be tedious with this thing and it has a tendency to spill lots of smoke whenever you open the door. when it's warmer out you usually do 2 or 3 restarts a day which is a pain.
I think going to a princess would be a good idea. I know ash has a higher but value than elm, how many hours could one get out of a full load of ash? Having to fill the stove only twice a day would be fantastic. the house is also somewhat transient with people coming and going, would maybe a king work for this situation? The larger the box the better IMO. 24 hour or longer burn times would be awesome but probably not realistic.
Well aware of the caveats of a cat stove. I think the positives heavily outweigh any negatives in this situation.
Well, I *always* think that a Princess is a good idea, except for those brief and challenging spells here when I think that a King is a good idea.
I cannot speak to your wood supply; we burn mostly oak because that's mostly what we've got for hard wood.
I can tell you that morning restarts on the Princess are stupid easy. One restart a day is all it takes- and that's assuming that the load burned down overnight such that an actual "restart" is necessary.
Fresh starts are stupid easy as well. This is the easiest stove to start and maintain that I've ever experienced in my life.
Our stove pipe is straight vertical to the ceiling, with two 45' elbows to zig zag around a ceiling joist/roof truss, then a straight chimney through the roof. We live on a spit of land on a peninsula surrounded by water. Our winter winds out here are remarkable- sometimes just because it's Tuesday AND HEY! THE WIND! IT'S 60 MPH! So draft isn't a problem and sometimes we have to crank the stove down just because of the draft.
Our recent Arctic blast was interesting because our real temps were at or near 0'F, wind chill was below 0'F, and of course the wind was howling- we had a winter hurricane, basically. So the challenge was to burn the stove at a high enough temperature to keep the house warm in challenging conditions, but at the same time not go to bed with the stove running flat out with that draft, and simultaneously keep enough wood in it overnight to keep it lit the next morning.
The Princess ran like a charm. Even though we didn't get our longest burn times with that draft and the need to run it more open than we typically do for longer periods of time, and even though we burned in the center of the "normal" range on the thermostat (basically dead center medium) overnight/while asleep, we had enough coals in the bottom of the box to start the stove right back up again in the morning.
Bonus round, the proprietary thermostat kept the Princess stable even in that draft while running at thermostat setting 3 or 3.5 out of 4 (while we were awake.) We had to reload more often but the stove didn't "get away" from us. (I can say much this for sure: the door glass is clean, the chimney's got to be clean and if the CAT is not clean I don't know what will do it after that weather/burn spell.)
We're finally back to stable and calm weather here; it's 36'F with no wind. I haven't shoveled out the firebox in, geez, in two weeks? It's been at least a week and a half, even after that epic burn. The Princess is humming along quietly and merrily on about 1.5 out of 4, basically at the very lowest setting of the "normal" range on the thermostat. The coals in the bottom of the box are burning into fine ash. The house is comfortable.
As far as smoke spilling back into the house, I can't speak to other stoves, this is the first wood stove we've owned/operated in our own house (family members, parents, friends, neighbors had wood stoves when we were kids/teenagers/young adults but this is our first) but no problem with the Princess unless *we* screw up. Open the bypass/take the CAT out of play, and if you are burning on low (and it's not hella windy outside) open up the damper before you open the stove door. Voila! No problem. That's with our stove pipe/chimney/draw. I guess every set up is different.
In fact, when the wind is howling, we have to turn the thermostat down (roughly the equivalent of closing the damper) to reduce the airflow while we reload. Under those conditions, we don't get smoke spillage into the house even with the thermostat turned to low.
As far as reloads per day, during calm winter weather like we have now, it's realistic for us to load once in the morning, once in the evening, and maybe top off before we go to bed. We can roll like that for days, even weeks. If the wind picks up (as it does out here) that will influence our burn times more than anything- even more than the outdoor temperatures.
Every once in a while I wish we'd gotten the King, when conditions out here are particularly challenging. Of course, we could use the gas furnace, BUT THAT WOULD BE DECLARING SURRENDER. HA! LOL. For the vast majority of the burn season, the Princess is enough.
I hope this word salad helps!
![[Hearth.com] 2017-18 Blaze King Performance Thread PART 2 (Everything BK) [Hearth.com] 2017-18 Blaze King Performance Thread PART 2 (Everything BK)](https://www.hearth.com/talk/data/attachments/220/220277-c9e60dfce624b6ac47da767351c0aaf4.jpg?hash=3uddOTQuI6)
