![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
1) Q: Can you bugger the cat up by opening the stove when it is too hot and what is the correct way of opening a hot stove, baffle open should be ok?
A: Yeah, open the bypass and let the cat cool off for a few minutes. But you are generally burning the entire load down, and the cat is inactive by the time you have to open the door to reload.
Read your manual several times...this stuff may be covered but if not, you may learn lots of other good stuff.
2)Q: Can you bugger up the cat by going above the active zone and what type of safety factors are built in to the gauge up top and how much can we go over ;-)?
A: Yes, the "wash coat" (catalytic metals that are sprayed onto the substrate) can peel if the cat is subjected to temps over 1800 frequently or for extended periods. On your unmarked BK cat dial, I think 1600 is about 3 o'clock on the dial, and I would try to keep it under that...others may disagree and run it higher.
Can you bugger up the cat by shutting the baffle to early as there must be moisture that goes through it on a reload when it is still very much in the active zone and closed quickly after the reload and burnt on high for 1/2 an hour.
1)-you don't wanna open the door on a hot cat and 2)-toss wet wood on the coals...that would be worse yet. A steel can may not be as susceptible to some of this abuse...it won't crack like a ceramic cat. Still, the less a steel cat is subjected to rapid expansion and contraction, the better I would think.
Now, I would be more concerned with closing the bypass too soon, with the cat not being in the active zone yet. It seems to me that you would then get creo deposited in the cat, which would later be burned to ash when the cat finally lit off, but would stick to the inside surfaces. I don't think that would blow out as easily as fly ash from the firebox that sticks to the face of the cat.
1) No sometimes you would like to throw a couple of logs on before bed or before leaving the house to ensure it runs through the absences. The question was best procedure to open the stove when it is hot and not adversely effect the cat. Closing the baffle stops air from running through the cat, correct? I would think closing the baffle and waiting 2 minutes, in a hot stove, will not cool the cat to any great extent but possibly that is the answer. Just closing the baffle should stop the air from rushing through it, forget the time frame. Also maybe it is better not to crank the air to full and run it for 2 minutes prior to closing the baffle as the manual states when the stove is hot. Having to let it burn down to nothing when it is cold is obviously not the answer.
I have read the manual and it say not much on adding to a hot stove only "reload instructions", with wait 2 minute, wait 2 minutes, this maybe hot and end of fuel instructions. It explains the time frame not to get back draft. My draft has always been good and I have experience on how to open the door without smoke escaping on a hot/cool stove. Open the baffle but you do not need to give it full air to get the fire ripping prior to opening it. Crack the door slow.
Question: Proper procedure to open this stove hot to add wood? Is it the same as end of burn reload and do you need to open air full?
2) Thank you. How long is a long time, is a spike during your mandatory half to one hour burn a problem?
3) On a reload the cat is in the active zone. Manual, load wood and close baffle, as it is active, this new wood has moisture in it. We were informed by the rep that moisture contained in the wood can be a problem for the cat. You must understand that owners are not all wood guru's running around with a moisture meter. Drop it, cut it, split it, and throw it in the stove. The reason in the past I cured 2 years (and continue to) is because it burns better not because the stove can not handle it. Humidity levels fluctuate, this will be reflected in your wood. Kiln dry lumber is usually 15% (design moisture content) but can be a lot different sitting in your local lumber yard or your home.
Wanted the rep to let me know how tough these cat are so I have a feel for how much it needs to be babied. No response and time will also answer these questions. I purchased a spare at the time of purchase based on a hunch and because I usually learn by hard knocks. I have no problems with the cost of a cat, just the cat losing its efficiency.
Thanks for the response.
Regards
