Also note you guys mention numbers on the thermostat in some of your posts, mine just has a increase in thickness line from 12 to 6 o'clock, 12 lowest clockwise to 6 wide open. Is it clock positions you are referring to or do you have actual numbers behind the knob?
Thank you HB much appreciated. So 3 o'clock is 1.5 and 4 numbers at 60 degrees starting at 0. Helps reading older threads.
Regards
EDIT: Is this Jetsam for real?Pretty constructive post dude.
Not exactly.
1 is at or near 1 o'clock
2 is at 3 o'clock
3 is at or near 5 o'clock
There are dots between the numbers that would represent .5, the last dot is at 6 o'clock which would represent 3.5
I don't believe the inserts, as Shayne has, ever had numbers. Just dots. My 2012 princess stove has actual numbers and graduations thank goodness.
Yes they changed it. A few years back and some folks are still not over it. Highbeam summed it up very well. No 2 setups are the same, too many people were getting hung up in the fact that their stove wasn't performing as well as their neighbors on the same number setting. Remove the numbers, remove part of the problem was the thought. The insert always had dots rather than numbers as far as I know, the stoves all had numbers until a few years ago, now we have the *swoosh*... O,clock references are just fine, it works.From Tarzan's last post I am starting to understand this one. New model change the dial, got it.
Regards
Yup, that's how board people get owning these stoves, normal people are busy loading, adjusting the air every hour, looking at stove top thermometers then comparing it to smoke pipe ones, bringing in more cut firewood for the midnight, ext.. we just sit here and argue about numbers because there's nothing to do since we have long burn timesOh yeahI've been waiting for the numbers vs swoosh to rear it's ugly head lol. Here comes 10 pages of arguing with no solution being made except for bk needs to offer both.
[emoji23]The numbers were removed from the dial a few years ago. God please! Don't get this started again!
I'm constantly changing stoves here, it's my thing. I always have a Blaze King and some other stove, typically a non-cat. The BK does the majority of our heating, the other is mainly just for our front room or when the temps are in the teens. The non-cats I've had easily consume 3x the wood the wood the BK consumes. Same environment, same wood. They have a beautiful fire and typically make too much heat, leaving me with burn times that are disappointing.. There will always be a Blaze King on my hearth!Bored new princess owner here that is why I am here raise Sh!t about dials.
Of course even if two were burning the same species hardwood in exactly the same build home with one harvested and living in Northern Canada and one from Washington State the growth rates of the species would be different and hence the BTU output. Way to many variables in the equation to determine that.
I have a question how much did your consumption go down when you switch to a BK Cat stove and what were you running prior? That would freeze some of the variables based on average temp over the long term, same fuel, same house, same stack etc. The princess is stated as 81% efficient which makes me feel like I am doing something, not just for the air but for the forest, but I have no data on what my old one was or if it is as simple as 81-x when it comes to consumption. Now it appears that we burn at warmer temps since this stove purrs so nice which will also complicate it a bit but I am interested in what others experiences were regarding consumption after the switch.
Regards
Wow! I knew you burned a lot, but that's insane! I went through 2/3 of a cord from October 8th through November 26th (over seven weeks). Granted, it hasn't been super cold yet this year.My wood consumption dropped from as high as a cord per week to roughly a cord per three weeks, when I switched from Jotul to BK.
Happy camper here and perfect timing as our temperatures are going to dive in the coming week. The King was installed today and we are doing the first burn with intermittent smoke alarms. Got the OAK installed through the floor and out with little problem so now I just need to repack insulation and put the sheetrock back up. First load was a lot of limbs with about 2 big splits of tamarack and 2 of fir. Cat needle is pegged and the smell is starting to fade. Will see how long the first load makes it running with it turned all the way up and the fan on high.
Will do. I have a big bed of glowing red coals now. It is burning down faster than I thought it would, but everything (fan and setting) is still on high and we did not fully load the stove. Thinking I can throw a full load in late tonight and really stuff it before dialing it back a bit and turning the fan down some. Looking forward to learning how it performs, but wish I had some of the old oak I used to cut for grandmother in Florida!
