Yes...yes, it does. You should be proud.Does this make me a stove nerd?
The red fluid moves up and down the tube depending on your draft. This one mounts to the pipe so I can constantly monitor my draft on different setting and in different weather conditions.
A 1/4" SS tube. The gauge screws to the pipe.Magnetic? What is inside the pipe?
The liquid angle makes it a bit difficult to read as you need to go by the middle for the scales to match at zero - but I guess not so hard to do. And now that you know this, what do you differently with the controls on your stove?The red fluid moves up and down the tube depending on your draft. This one mounts to the pipe so I can constantly monitor my draft on different setting and in different weather conditions.
You read it by using the trailing edge of the liquid.The liquid angle makes it a bit difficult to read as you need to go by the middle for the scales to match at zero - but I guess not so hard to do. And now that you know this, what do you differently with the controls on your stove?
Yes and the tabs are retainers. When you pull the cat, they are removable. We designed it so no tools are needed to disassemble, although a pocket knife make it easier.baffle plate: that plate that swings on the hinge just behind the cat probe?
There are tabs that hold the welded nubs from being lifted up much... they looked to be removable if I took the cat out, but didn't want to go that far just yet. End of the season I will.
Not a problem, we are OK.Sorry..headed to airport.
Even with the stove turned up to full, as long as the bypass is closed, you won't over fire the stove. While it may get toasty in the house, the stat will keep it under over fire.
Not sure how true this is for everyone. I have forgotten to turn mine down after reload and the stove top got up to 860 with no sign of slowing down. Bypass was closed. It scared the hell out of me. I'm not sure how hot is too hot for this stove, but that seems excessive. My wood is usually below 10% moisture content which may be the issue.Even with the stove turned up to full, as long as the bypass is closed, you won't over fire the stove. While it may get toasty in the house, the stat will keep it under over fire.
I'm assuming your stovetop temp was taken directly above the cat? That's a common high temp in that location, move it to one side of the stovetop for a more average temp reading. Usually about 650.Not sure how true this is for everyone. I have forgotten to turn mine down after reload and the stove top got up to 860 with no sign of slowing down. Bypass was closed. It scared the hell out of me. I'm not sure how hot is too hot for this stove, but that seems excessive. My wood is usually below 10% moisture content which may be the issue.
If you measure directly over the cat, then temps as high as 900 may be seen. Dry wood, excellent draft and all being equal, such temps are o.k. Remember, the cat gets to 1,200F or higher.....Not sure how true this is for everyone. I have forgotten to turn mine down after reload and the stove top got up to 860 with no sign of slowing down. Bypass was closed. It scared the hell out of me. I'm not sure how hot is too hot for this stove, but that seems excessive. My wood is usually below 10% moisture content which may be the issue.
The over the counter thermometers have a wide range or margin of error. The IR guns seem to be more consistent. What we all need is one of those FLIR cameras!When burning on "3" with the blower off my Rutland thermometer will reach about 750*F before slowly settling in at around 720.
I doubt that's accurate readings but it's consistent.
They work for all sorts of stuff....like measuring exhaust gas temps from a BBC set of custom headers. Tells you which cylinders may be running a little hotter than others.
Maybe I could take a picture of my wife while she is standing there with arms crossed to see if she is heated!
