I suppose the plate could still be pushed back out of place. I thought you were lifting it straight up.
I vaguely remember some type of change with those retainers at some point. Maybe not?
I ran 12 ft last winter without a problem. Seems like most were at 15 ft, and i see now 15 is recomended.Oh by the way I finally measured the pipe and I only have 12'8" of draft going on. I think insulating will help but might also have to extend the chimney a bit. Thoughts???
There are metal brackets that mount in the catalyst housing, the cat slides in after those are in place. They have tabs on the bottom that keep the bypass plate from being knocked out of place. That's how I remember it anyway, I don't think the older models had this feature. I can't remember for sure, I so rarely have to remove a Blaze King cat.
I tried this on a Princess I cleaned yesterday, I did not work. I could get a few finger tips in there, but not near enough room to work. I pulled the pipe to expose the mess that was sitting right behind the cat. That bypass plate ain't budging! It's 3 years old.IIRC, I think I read BKVP mention that the newer stoves don't have these. Probably in one of the last two monster threads.
My (former stove) and my sister's both have them, built in '05 & '06.
True, but you have a bit more heating challenge than MtnBURN. I'm curious to see how you end up balancing heating needs and burn times. Also interested to see how you manage to cut down those 20 cords of firewood ... got a bit of that to do myself ... hoping you will come up with a good solution I can benefit from.Looks like I won't be the only one burning two new BKs this fall...
That made me LOLSince it was raining today, I decided to go check out a BK in person. Did a dealer search and found a shop about 27 miles from where I live. Called first to see what they had in stock. Here was the conversation:
ME: Do you have any Blaze King freestanding wood stoves in your show room?
Salesman: Um, not sure. Hold on, I'll check. (two minutes later). No, we sold our last floor model. But, we do have the Broil King Keg.
ME: OK, thanks.
So, which of these BK's do you like?
First is Keg 5000, Second is Keg 2000
(broken image removed)(broken image removed)
ME: OK, thanks.
I would appreciate a pm with contact details...I'm certain I can fix this!Since it was raining today, I decided to go check out a BK in person. Did a dealer search and found a shop about 27 miles from where I live. Called first to see what they had in stock. Here was the conversation:
ME: OK, thanks.
View attachment 161646 View attachment 161647
That's ridiculous! I assure you BK is working hard to address this issue. There is no excuse for such ignorance...Since it was raining today, I decided to go check out a BK in person. Did a dealer search and found a shop about 27 miles from where I live. Called first to see what they had in stock. Here was the conversation:
ME: OK, thanks.
I have one that's very similar! It'll out burn a Blaze King!I want one of those kegs!
pictures of the cardboard stove pleaseFor my first post to the forum, I hold all of you responsible for my obsession with Blaze King stoves. Despite having a friend who is a long time wood burner recommend a non-catalytic Pacific Energy, I was convinced by the passionate, wise, and enthusiastic people on this forum (that's you guys).
Stove guy is coming to check out the house on Monday. I am looking at the Blaze King Princess for our approx 1200 sqft house (single pane windows), and built in 1920-ish. If you couldn't tell, I live in Portland. I just moved up here this year, so haven't seen much rain/cold yet, but apparently that is supposed to come. 2 cords of wood have been drying in the back yard, since April...hope that will be enough.
Based on reading through last year's performance thread, it sounds like I should use double wall pipe to maximize the draw. Any other tips?
Just to tell you how obsessed I have become, I built a cardboard simulation of the stove to get an idea of size and placement for our living room.
Cheers.
Cardboard. A new contender in the cast iron vs soapstone vs steel contention?pictures of the cardboard stove please![]()
