BKVP
42 in Walla Walla this a.m.I think he's hustling to get his BK connected and running again. Nights are starting to get chilly.
Highbeam, how was the fishing?
CAUTION! There is a 7/16 keeper nut under the head of the adjustment bolt. Loosen this nut several revolutions before turning the adjustment bolt. Then turn in 1/4 revolutions and check each time with dollar bill.Hey Guys,
I have my stove out because I insulated the liner and installed a block off plate. I have been going through the stove and did the dollar bill test on the bypass and it slides out pretty easy. Should I try to tighten it or replace the gasket? This has happened because the thing I clean my chimney with has worn it out. At least that's what it looks like. Also how do you replace that gasket? Is there a way to take the bypass door off? Where do I get the gasket material? Sorry for all the questions.
If you wish to replace the 5/8" gasket, I can walk you through it. Have gasket and high temp furnace cement or glue handy when you call.
Chris
Why can't you clean it from the top with the bypass open?Hey Chris, yep found that nut and loosened first. I tightened the screw as far as it would go and it was still not tight enough with the dollar test. I need to replace the gasket. Where can I get one? I am officially modifying how I clean the chimney! With the bypass closed. I will have to take out the cat to vacuum out the top of the bypass though. Have never taken the cat out so hope that is easy enough. Also hope the new insulated pipe and block off plate do their magic!
I understand that. What can't it be cleaned traditionally? Is your roof exceptionally steep?Because the sooteater has trashed the gasket!
I have been cleaning it from the top with the bypass open. The sooteater makes it all the way into the stove and hits the gasket first. So now I am going to keep the bypass closed and use the leaf blower method to suck it all out which I already do for my second chimney.
The Princess is super easy to clean from the bottom up! The angled flue collar makes it a breeze.I have a sooteater and use it from the bottom up. I thought that the insert would be exceptionally easy to clean this way since the liner attaches at an angle. Bottom up also allows you to avoid the bypass gasket.
I have no problem removing all of the chimney debris from the cat chamber with a regular shop vac. The trick is that you need to grab a hold of the bypass plate and lift it up towards the stove top to gain access to the bottom rear of the cat where the debris is otherwise inaccessible.
Removing the cat requires the installation of a new gasket around the cat. Also, the chances of breaking the cat increase each time you remove it. It's not hard but you need to apply some careful force to the cat to overcome the expanded gasket.
There are metal brackets that mount in the catalyst housing, the cat slides in after those are in place. They have tabs on the bottom that keep the bypass plate from being knocked out of place. That's how I remember it anyway, I don't think the older models had this feature. I can't remember for sure, I so rarely have to remove a Blaze King cat.Okay so maybe I'm not stupid after all lol. I tried to push up on my bypass and it didn't budge. I would like to know for sure in case I need to do any further cleaning.
I recall BKVP commenting somewhere that very low moisture wood can lead to excessive cat temps. I just have never experienced it, even though my wood is 12-15% MC. I think the highest I have seen is maybe 75% of the active range on the probe.
I suppose the plate could still be pushed back out of place. I thought you were lifting it straight up.You don't just lift it, you slide it up from the 1/3 open position. Kind of slide the non hinge side of the plate away from you and up. My princess is a 2012 model so I don't know if that is considered "older" but your princess insert has some different internals. I can slide the bypass up enough to reach my fat fingers in there and touch the back of the cat. When I removed my cat I did have those SS clip in retainers.
