Woody harrelson
Dealer onlyCan you buy from Blaze King directly or do you have to go through a dealer? Any retail dealers that sell Blaze King like Rural King or Tractor Supply or is it just small business owners? Thanks
Well that's not good.![]()
unless something has changed, BK's dealer locator isn't especially accurate
Several members have run into this problem with the "dealer locator" then called BK and gotten a list of recommended dealers that did not show up on the locator.
They're nice folks, speak English with a WA accent, and will answer the phone to talk with you.
If you do an Ashford 30.2, where you replace this ashpan with an extra 6" of belly, you could sell me two more stoves. [emoji12] Given the difficulty of getting the ash plug out and back in, versus just shoveling out the stove, I'd rather just have the extra belly depth!Belly Depth:
King models....... 9"
Princess Models....... 6"
Princess Insert......5.75"
Ashford 30.1, Sirocco 30.1, Chinook 30.1....2.75"
Ashford 20.1, Sirocco 20.1, Chinook 201.....2.75"
Briarwood II.......1.75"
I purchased my Ashford 30 in this fashion through a non-dealer. Mostly because I was very comfortable with the service I was getting from the local shop with my primary heating system. It was considerably more expensive in my case, but it can be done.I was getting some Pacific Energy parts from a dealer that didn't sell BK one day, and I was whining about the trouble I had finding a BK dealer that would order parts for me. He said he could get any part or stove I wanted through his distributor, he just wasn't a Blaze King dealer.
Might pay to ask around. And unless something has changed, BK's dealer locator isn't especially accurate.
That same dealer also has a store somewhere further south, can't remember where. They also don't display anything in Columbus, they are primarily a chimney sweep business. They recently picked up the line.So I called Blaze King and she confirmed the nearest dealer to Louisville is in Columbus, IN (ironically my hometown). [emoji36][emoji36][emoji36]
She was going to check with someone else there and get back to me. Surely to God there has to be someone in the area that deals Blaze King. They're not a tiny brand are they?
A local guy here that gets fantastic reviews and did my fireplace sweep last year deals with Regency stoves. Don't know much about them.
Anyway, hoping to hear something back from Blaze King. I emailed the Columbus guy just on the long shot they service all the way down here. About 1h15m away. Doubt it.
Surely theres a dealer in KY..Still haven't heard anything back from Blaze King yet and I did a dealer search for the entire state of Kentucky. BKVP, any advice? Surely I'm not the first person in the state of Kentucky in need of a BK dealer.
The rest of you Kentuckians that have BK stoves, how did you go about acquiring yours? Looks like I'm heading towards DIY whether I like it or not.
The design and efficiency of the BK line is what I found appealing along with all the positive reviews here. Maybe I need to branch out and look at other brands that my local delaers support like Regency. What say y'all?
We've got most BKs on display and in stock if you wanted to make a road trip to Bloomington, IN. We travel to extreme southern IN, but haven't ever went into KY. Wouldn't be possible this time year anyway.
So need a little advice.. I currently have marginal draft on my Ashford 30.1. It's ok, but there's a good amount of smoke, and the cat has stalled with a load of envi blocks. Running 15'8 of pipe with 2 30s in the attic. Going to be adding a couple feet, but how much to add? Was going to put another 2' section on top, but not sure if a little 2' would really make a difference? Should I add 4' instead?
After 5' above the roofline you need to add braces to the roof. Certainly go up to the 5' line at a minimum. Above that it can get a little funny looking and hard to clean from the top.
I already have roughly 4' above the roof. Any extention is going to require a brace, I know that... wondering if 2' would do me any good, or should I do 4?
See Highbeam's post 594, just a few up from yours, in which he addresses this issue. His answer is spot-on, in that you almost can't go too big with a BK... they can be run at remarkably low output temps.Hello Blaze Kinger's . I have an 8 inch pipe on my old stove, so I am looking at the King model because I don't want the expense of changing the chimney.
However I am worried that the King might put out too much heat. The heat comes in handy when it is super cold and the power goes off, but as the stove is beside our dining/living area if it gets too hot when outside temperature is around the freezing mark we won't use it. (Which is the issue with our current stove that does not really damper down)
Blaze King state that the low BTU rate is 15, 475. I am wondering if I will have any success burning at a lower rate with a smaller fire or bigger damper.
We do live in soft wood country so that should help. Fir and hemlock mostly.
Also I am wondering about the fresh air kit. Will the stove burn hotter or cooler with the fresh air? I am probably looking for less performance. I am also thinking a blower is a good idea but have the same question with it.
The other option is to go with the 6 inch model and convert to my 8 inch pipe and see how that works. I have about 12 different opinions from 8 people on that issue.
Thanks!
