Whats the best brand of chimney system out there. I am looking at the excel brand for my new install.
Please. Not another damned oil thread...... Have you ever asked an oil question on a motor head board. Similar results may surface here soon.
You left out the amzoil fan boys favorite.I've used Royal Purple Red Line Mobile 1 in every high performance...
Edav, there are users who have similar experiences and users that do not. Parallax, you and I along with others that have chimed in will tell you that sometimes seemingly perfect conditions still result in smoke smells.I think you just need to run a slightly higher setting on the T stat. These stoves aren't necessarily a set it and forget it stove, closer than any other stove out there though. If you smell that smoke smell, give it a little more air and it will go away. The range that says "normal", tends to be just that. I find that if I run in this range I never have to fiddle with it or smell any odors.
I have seen evidence on a few service calls. It's typically a door gasket. But I have a few Princess inserts that have too much draft, they blow out a cat every 2 years or so. It's very uncommon, but it happens.I'm treading in the land of ugly stoves.
Searching Google Images, it appears the Blaze King thermometer does not show actual catalytic temperature... just "inactive" or "active". Moreover, there's no, "oh chit" too hot portion of the dial. So, I guess asking how hot you've seen your cat run is not going to generate many useful answers, but have you ever seen evidence of over-firing your catalytic combustor?
On an insert, there isn't a solution really. I have had them keep the air on or near low and has helped.What's the proper solution to the draft problem, webby? Variable pipe damper? Something fixed and calibrated to 0.05 wc?
Dwelling on this a moment, this seems to agree with my experience, which is against convention. Jotul's manual repeats advice often found here, to raise the primary air to reduce cat temps, by burning off more of the wood gas in the firebox. My experience counteracts this oft-repeated advice, as I find turning up the primary air exponentially increases wood gas production, and thus cat temp.I have seen evidence on a few service calls. It's typically a door gasket.
Right now I'm playing games with throttle and bypass damper, trying to keep mine under 1800F, and mostly failing. They seem to peak 2 - 3 hours into the burn, and I loaded at 10pm. Hence, the interest in BK.I just took a peek at it for you, I loaded the stove about an hour ago, it's dialed down to the low end of normal with some light flames in the box, stove top is around 650 over the cat, the probe is a tick over 1400 and the cat is glowing bright.(blowers off)
