What length are you guys with kings cutting your splits to? For the most part I'm 18". The bottom part of the stove is kinda irritating, I think it needs 17 or less but the rest of the stove can take 20" guessing. 17 is an odd annoying number to me, makes all the math difficult. I've been cutting 6' logs throwing in truck and then bucking 4 18" pieces. Plus 18" helps me figure my cords as well.
Does the BK only need a 12' chimney? My Ashford 30 was a minimum of 15' in the manual, I believe. Don't skimp on chimney height if you can help it...Okay guys. I am almost done asking my dumb questions. Started with the flue length and my last one was about the oak pallets....so far I am too short with my current flue and the oak pallets are a bad idea due to paint and zinc.
So....before I actually install my sirocco 20, how big of a OAK diameter will be sufficent or what is the rule of thumb with these blaze kings. I am having a box built to drop straight through the floor...just want to know if I should go 3" or 4" pipe off the tail of my box. Just so you know I am planning to update my entire chimney system to a minimum of 12' from the flue collar.
Bring it!
Bring it!
I have about 12' total height, all double wall. I was prepared to add if needed but maybe it's the drafty home or the West Virginia air, I don't know but my setup is working fine.
Are you on the top of a hill? Is your house chimney the tallest thing around? (i.e. you're not surrounded by woods?)
How well a chimney drafts is largely dependent on the surrounding environment.
Depends on setup, some get away with setting 1, others are up higher - 2.5With temps in the teens or low 20s what setting do most go with?
"Normal" or medium.With temps in the teens or low 20s what setting do most go with?
I chose the 20 partly based on the dealers suggestion and partly because it is dam near the right size physically for the install spot and my place, I have about 1200 sqft. As long as I get minimum 8hr burns thats all I care about. Just want it to heat through the night and while I am at work.Oooh, a 20 model stove. What made you choose that stove? The 30 model is actually able to run at lower outputs than the 20 with a burn time of 50% longer. The only reason I would consider a 20 model is if you absolutely can't live with the extra couple of inches of physical size.
How long will your OAK pipe be? I used 3" for my OAK to match the inlet pipe on the stove. Mine drops into the crawlspace under the house. I would recommend 3" pipe unless you run is really long and even then you could bump up to 4" after you've left the hearth area.
I run mine on pretty much the same no matter what. Fans or no fans is what I use to regulate heat output. With that said usually on the lower edge of the normal zone.(just a touch below the "n" in normal). I find outside temps change the draft enough to change the temps at which the stove burns. When the temps dip into the minus I usually burn on the "n" or the "o".
Blaze King just replaced my fans. The old ones had melted. The blades were plastic. The replacement unit arrived with metal blades. Someone figured something out.
I never really understood what a "hollow" was until I saw it with my own eyes. I went to West Virginia a few years ago for that monster wind storm at the end of June to help restore the power. I think hollows are in Jersey terms "freakin awesome" it was some of the most beautiful country. Windy dirt roads and a zillion 1200' mountains everywhere. We stayed at Stonewall Resort for a couple weeks and ran the I79 corridor from Clay County to Williams town, again what a trip and great looking countryI live in a hollow surrounded by wilderness mountains. No joke.
I am just as excited to see places like Jersey as you are to visit here..
