Daleeper,
I was instructed to open the bypass for about an hour and burn the fire before closing it after making sure the cat probe is in the active zone.
I do not really turn down the thermostat. If I do it is only to about 2.5 out of the maximum of 3.
The moisture meter i purchased indicates all wood sources at or below 14% and I did try the compressed logs which did not make much difference.
The cat probe thermometer raises up and then starts to decline if I do not add more wood. It is only stable for a relatively short period of time.
Is that 14% on a fresh split? What type of stove top temps are you getting during the burn? Take us through your load process from start up or fill up, pictures are a plus. On a cold stove you should be able to get the cat active in less than a half hour.
